Results 1 to 3 of 3
Thread: 4bdi swap 110
    Dec 2010
    cairns
    4bdi swap 110
    hi all as I mentioned in a previous post am doing a engine rebuild on my 300tdi early next year was going to do a few extras like, up graded turner engineering head, and vnt turbo.
    someone mentioned a 4bdit instead anyone any opinions on this conversion
    cheers all
    Feb 2013
    Sunshine Coast
    Plenty of opinions in this thread. Although perhaps needless to say, mine is that the swap is worth it if your 300 is coming up for rebuild. Engineering it is the struggle.
    JDNSW's Avatar
    The 4BD1T is probably going to have better low down torques, and certainly more rugged, durable and reliable.
    On the negative side, it is (a lot) heavier, rougher and a lot more work to install than overhauling and upgrading your existing engine. Two key problems exist - the required flywheel housing and bell housing are scarce as hens' teeth (means you may have to get custom ones made - $$$), and you need to look at whether you can get engineering approval before even starting. This will depend on the date of your vehicle relative to when the 4BD1T ceased to meet ADRs. This willo be critical to whether you even want to think seriously about it.
