Results 1 to 10 of 16
Thread: Legalities of Outter side tub mounted spare wheel carrier
    Jun 2012
    Melbourne, VIC
    Hi Guys
    Planning to do a bit of camping this year in my series 2a ute top, Im going to mount my Rooftop tent directly onto the top of the tub and use underneath for storage etc.
    Currently I have my spare wheel mounted in the wheel well on the inside of the tub but that will need to move as it sticks up out of the tray and will get in the way of the RTT.
    At the moment I have 3 options for spare wheel storage:
    1. Just chuck it in the tub - Not ideal as it will take up space/be messy
    2. Bonnet mount - Currently have a non mountable type bonnet, but have a mountable one kicking around somewhere.
    3. Side tub mount - I bought a whole heap of ex-Mil parts a little while ago, of which included a spare carrier that hooks over top of the tub and hangs the wheel over one of the sides, so that the spare sits on the side of the vehicle. While being very cool (IMO) I'm not sure of its legality for use on the roads. Has anyone had any experience with these/know if they are legal? I assume they must've been used on some army vehicles at some stage so its possible they're OK to still use?
    See pics of said unit -
    Cheers in advance for your help guys.
    Dec 2009
    Queensland (though occasionally elsewhere)
    I'm not sure about legality, but I can confirm its coolness.
    Narrogin WA
    I doubt it would be legal as it makes the car over-width. In any case how does the load of the wheel against an aluminium sheet, stop it bumping and damaging the panel badly?
    I think the bonnet is the best option.
    Alternatively, see if you can find the parts to mount the wheel vertically inside the body at the rear. It could be covered with a vinyl cover to keep the occupants clean, if there is enough room for all of you,
    Cheers Charlie
    in the wild New England, NSW
    Quote Originally Posted by chazza View Post
    Cheers Charlie
    How is "over-width" defined ??
    I imagine the use of the tub side mount may possibly contravene some other unprotected protrusion regulation but I agree thaht it would be a handy spot.
    I'm a great user of the bonnet mount (and I know a lot on here are not), and I can't think of instances where I have had any issues with it.
    May 2008
    Bundaberg Qld
    IIRC, the max protruding past the outer limits of a vehicle (not including the mirrors) is 150mm. I would hazzard a guess that the spare would be more than that.
    With this in mind, how far will your RTT hang out past the body line ??
    Mar 2010
    Queensland
    12.97 MB
    Hello Philry,
    Another option could be to construct a rear mounted pivoting spare tyre holder like Debruiser has made on his shorty. See the photograph at Nick's 1975 Series 3 SWB. It also stores the hi-lift jack without taking up storage space.
    Kind Regards
    Lionel
    Jun 2012
    Melbourne, VIC
    Cheers Charlie
    I was also wondering about the possible panel damage issue, it will be bolted onto the tub rail, and I would put a bit of foam on the contact area down the bottom, but even though its 4mm steel I would imagine it could still bounce and potentially do damage.
    Quote Originally Posted by pop058 View Post
    Yeah spare wheel would more like 250-275mm at a guess, looks like its probably not the best idea to use this mount.
    The RTT is only 1400mm wide so actually sits within the width of the car.
    Quote Originally Posted by Lionelgee View Post
    Hello Philry,
    Kind Regards
    Lionel
    Cheers lionel, could be an option, I'm no good with fabrication so would need to commission someone to make it/modify the rear chassis to suit.
    Thanks for your advise guys, I might dig out that mountable bonnet first off and give that a crack, see how i like peering over the spare
    Oct 2013
    Armadale
    Smile
    I have my spare mounted to the rear of the seat wall in the tray, which keeps it out of the way when in ute or hardtop, i have the bonnet mount as well but it makes the bonnet very heavy to open. I can supply pictures of the tray mount if you need.
    Jun 2014
    Waitakere, New Zealand
    Being an older truck can you not just claim it came with the side wheel carrier and be exempt from such rules? Or does it not work like that?
    For example, a mate has a 1985 2 door 110 and he can legally carrier as many people as he can fit in the back with out seatbelts because it was built before some cut off date.
    -Bad
    WA
    Quote Originally Posted by BadCo. View Post
    You must have some strange rules over there...
    I agree with others that the protrusion beyond the "envelope" of the vehicle would likely be too much for the side mounted spare to be legal.
