Thread: Sunken tie downs
    Nov 2011
    WA
    Sunken tie downs
    I'm wanting to put a false floor in the stow/cargo area of my fourby. For utility purposes i'd like to put a tie down in each corner - I was thinking a M10 stainless eye bolt in each corner would do the trick, but a little more thought and I think a sunken tie down with no moving parts would be a better solution... if only I knew where to find them.
    Any ideas? I've tried to google a solution but my keywording is coming up empty. Not in a hurry to get this done so happy to buy off Ebay or Gumtree if that has the best options.
    Do you mean like these ones I bought from Bunnings.
    Nov 2010
    Murgon
    [ame="http://www.amazon.com/dp/B000HAEPAO/ref=pe_385040_30332190_TE_M3T1_ST1_dp_1"]Amazon.com: Progrip 822640 Surface Mount Tie Down Ring, 4-Pack: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/41AAteQUsEL.@@AMEPARAM@@41AAteQUsEL[/ame]
    I don't have a 'big hardware store' nearby so I bought these from Amazon.
    If that link fails they are ProGrip 822640 Surface Mount Tie Down Ring 4 pack. Freight was no worse than buying from someone in Australia. The ones that Ron posted look to sit a little more flush though.
    Apr 2013
    tie downs
    my local stainless and boating store have a range of tiedowns for expensive giant yatchs surely your local will have also......or google Bomond trading.. good luck
    Jun 2014
    Waitakere, New Zealand
    Try googling for recessed tie downs rather then sunken, lots of results that way.
