Results 1 to 8 of 8
Thread: Discovery 4 brake switch
    Aug 2013
    nsw
    Anyone out there know why the brake switch adjustment is adjusted by the stealer's each time I complain about a hesitation problem
    Brake switch is adjusted because the computer thinks you are braking, sending wrong messages to the gearbox - something like that.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    Sep 2011
    Minyama
    I believe the logic is if you have your foot on the brake you don't need the accelerator so it interrupts the signal from the accelerator pedal. Not much fun if you are used to left foot braking!
    Aug 2013
    nsw
    The hesitation only seems to happen when I try to accelerate away from a round a bout or corner,causes a bit of heart thumping in heavy traffic I can tell you.
    Yes. because your accelerating and computer thinks your braking at the some time. Gear box doesn't know what to do.
    1984 RRC, in hell
    Brisbane,some of the time.
    Quote Originally Posted by bob2s View Post
    It shouldn't need continual adjustment,something is wrong.
    Maybe it needs replacing.
    Mine has never been adjusted.
    May 2010
    Southern Sydney
    I had a similar hesitation problem in my 2010 D4. It would only happen intermitantly. The dealer couldnt correct it. I read on here that brake switches can cause this. In the end i asked the dealer to replace the brake switch. Its been fine ever since.
    I read a post here somewhere that there are two separate switches in the brake switch. One for the lights and one for the computer. It seemed that the brake light contacts could create some material that causes the computer switch to not work properly.
    I have never pulled a switch appart to see if this could actualy happen.
    In any case get the switch replaced . The switch costs $25.
    Peter
    Adelaide SA
    Have a look at this thread:
    http://www.aulro.com/afvb/d3-d4-rrs/...undabouts.html
    You will find heaps of info, including the cause & a possible solution to your hesitation issue.
