Results 1 to 3 of 3
Thread: Coolants
    Brownie2000 Guest
    Question Coolants
    Changing the water pump on my 1990 Classic Rangie and looking for views on what coolant to fill her up with?
    Jul 2008
    Gold Coast QLD
    In my 89 3.9 litre, have always used Nulon concentrate (green) mixed one part coolant to two parts demineralised water that you can buy in Woolies. So 33% solution which would cover all but Siberian climates. Search threads for refill procedure which is pretty critical to get all air pockets out - from memory the vehicle needs to be on a slope with nose upwards to ensure all air is expelled. The drain plugs on either side of the block can be a @#$% to remove and good idea to replace them with taps (Atlantic British I think had them). 14 litres the total fill I think so one 5 litre carton of concentrated coolant should do it.
    May 2009
    Tatura, Vic
    Cummins PG Platimun. I am using it in my TD5. It is reasonably priced and is a new technology coolant.
    Watch this.
    [ame="http://www.youtube.com/watch?v=_d8x2piUzB4"]Are all coolants created equal? - YouTube[/ame]
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
