Results 1 to 10 of 15
Thread: New Fairey overdrive
    Jul 2010
    Hi ,
    I fitted a completely rebuilt fairey overdrive yesterday . All new bearings shafts gears including the lay gear which I had made at a local gear cutting firm in Perth. We made a few modifications adding extra oil capacity byway of a can plumed into the sump plug and mounted at the same height using a hose. Took it for a test drive and it works great not to noisy and engages nicely. When I tried to disengage on the move it grinds I had to stop to disengage . Once disengaged no problem and the selector feels very positive it's definitely at full throw back. Any ideas on what could be causing this it may need to be run in a bit only done about 20 is so far. I am using the clutch as directed but was wondering if I need to blip the throttle when disengaging or some other technique to match the revs between the gears . It's mounted in my Series 1 109 ute.
    Mike
    Oct 2006
    canberra
    Can't help with the question but I like the catch can oil res
    Apr 2002
    Bellara 4507
    32.43 MB
    i have no such issues with my toro
    seems like an odd issue...
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Sounds like the synchro is not working too well. Could be incorrect assembly, needs to be run in a bit, or just trying to change faster than it can cope with - try pausing in neutral. Otherwise, just double declutch.
    darwin, nt
    My Toro has tired synchro rings so sometimes, if I mistime the changes, it can lock me out of the next gear. I have to go back where I was coming from and have another go. The whole unit is based on the Series 3 and Range Rover slow-synchro bits so I have to drive it with a little relevent respect.
    Your catch-can sump thing is neat-ish but I'm not quite convinced on the pipe from the bottom of the O/D. It hangs down a bit too far for my liking, and if it cops a bash it could so easily drop all your oil in one hit. I know, it's not easy to score the ideal fittings all the time, but maybe keep an eye out for a banjo-bolt set-up as you can, and be mindful of the dangly bits if you're offroading.
    I run my Toro without the lip on the big outer seal and without the entire inner seal. I decided to try it when I kept finding the O/D overfilling itself. It now shares oil with the transfer case without a problem. I am aware though, that should any bearings break up in the O/D they'll end up all through the transfer as well.
    Dan.
    69 2A 88" pet4 (still in disguise), 68 2B FC pet6 (still resting quietly), 74 S3 109" pet4, plus 26 other parts/project cars.
    Jul 2010
    Fixed it myself
    Thanks fot the replays guys ,
    I messages 107 Gus and he recommended adjusting the selector fork . I pulled the cover off and gave it a coupel of mill extra on the disengage side . It now works perfect. The lay gear I had made up is very quiet no high pitched noise at all. Just did a test drive using the OD like a splitter great on hills .
    Mike
    Jul 2010
    Banjo bolt
    Quote Originally Posted by dandlandyman View Post
    Dan.
    Banjo bolt yes that's the go good idea!
    Jul 2008
    Cant see what the catch can does with only one pipe in the circuit
    Narre Warren South
    Quote Originally Posted by chopper View Post
    I thought the same thing. It increases the oil capacity so you have to lose a lot more before it causes problems, also easier to visually check oil level.
    I'm not sure the oil will have any reason to move backwards & forwards through the pipe and heat transfer would be slow through the pipe section.
    Mike, what's the drain plug thread ? I'll see what banjo fittings we have at work.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Jul 2010
    More oil
    I have just increased the volume, of oil from .4 to 1 litre larger resivour means it takes longer to lose and doesn't get as hot .I contemplated putting a cooler and a pump but will see how this works for starters.
