Results 1 to 10 of 11
Thread: 3.9v8 - hard to start when HOT
    Apr 2011
    Wandong,Victoria,Australia
    Hi All,
    I wasn't sure if I should post this question in the 101 section (because that's the vehicle that has the engine in it) or if I should post it in the Classic Rangie section... Anyway.
    My 101 has a 3.9 carbie V8 in it - and it is an absolute pig to start when HOT.
    The symptoms are:
    * Starts up (usually) first go when COLD, no choke...
    * Drive it 10km (to the nearest petrol station - my local hang out)
    * Water Temp has only just hit 82c
    * Fill up the petrol tank
    * Try and start...
    * Foot flat on the floor, crank it (I had been told this is the trick with a 3.9)
    * No choke
    * Crank, crank, crank - probably for 2-3 minutes..
    * Eventually starts and off I go.
    * Seems to be using about 30ltr/100km
    It has been suggested that it is probably running rich (hence the easy to start when cold without choke).
    I am open to suggestions!!!
    The only other solution I have found - making it easy to start - is wait 1 hour after I have used it, so that it cools down... Which is a pain in the...
    88 Perentie FFR - Club Rego
    93 Discovery 1 200 Tdi - Club Rego
    03 130 Td5 Single Cab
    06 Discovery 3 Petrol
    22 Defender 90 - Full rego
    If your engine has carbies then the carbie starting procedure. The fact it is a 3.9 is not relevant in this case.
    When hot or cold - no throttle as it should fire by itself - when it fires a little throttle might help to keep it running.
    If the engine gets flooded then foot flat to the floor as it helps clear the system. So unless you are flooded you should not be flooring it.
    Yes sounds like it is rich - get it tuned.
    Avoca Beach
    Probably the carbs need an overhaul.
    Probably flooding because the needles and seats are leaking letting too much fuel into the carb bowl which may be then running into the manifold.
    Really the best thing to do is get a couple of carby Kits and go through them top to bottom.
    Regards Philip A
    Apr 2011
    Hi Phillip A,
    When the engine was put in the car (about a month ago) - each carby had a kit through it by a Land Rover mechanic..
    He was the one that said: "Start it without choke when cold. When hot - put your foot flat to the floor to ensure therevis fuel in the carbies, then crank it..."
    Parkerville WA
    Are you running the original in tank fuel pump or is it inline? I had a V8 lightweight in the uk that would never start when hot, turned out that the fuel vapourised and ran back through the inline pump to tank when hot and needed re priming to start. Put a small check valve in line and solved it.
    Dec 2009
    Williamstown, Barossa, SA
    When it was in mine, it needed choke, but was still slow to start when hot (most V8's I've owned have been like that... ). I never used to flatten it tho.... as it made matters worse. No throttle, no choke when hot and crank. Go try it, but find a slope to try it on!
    1995 Mercedes 1222A 4x4
    1969 (Now know! Thanks Diana!!) Ser 2 Tdi SWB
    1991 VW Citi Golf Cti (soon to be Tdi)
    'When there's smoke, there's plenty of poke!!'
    'The more the smoke, the more the poke!!'
    Avoca Beach
    it..."
    Well if the carbs are Strombergs or even for that matter SUs all I can say is BS.
    They should need choke to start and as posters have said no throttle when hot. Maybe your needles and Main jets are very worn and he found that it runs very rich .
    You may have a problem with vapourisation as suggested. That is why RRCs have a recirculation of fuel back to the tank. As the previous poster said what sort of fuel pump . The best is a ticker ticker Facet as original on a RRC as when matched to the return line runs at about 4PSI which doesn't overload the needles and seats..
    Regards Philip A
    I agree - when completely cold mine will fire but not run - choke out and fires up and settles into a smooth idle. The choke can be pushed back in straight away and it will still idle ok but there is no power and will not pull and stalls under load so choke is needed at full until mobile then pushed in 1/2 way until the engine gets some real warmth into it.
    The standard 101 system as the fuel pump in the tank and has a fuel return system so the carbs should not be getting vapour lock but the fuel but of course it could be in the manifold but not sure if that is actually an issue.
    Jan 2008
    Nowra NSW
    Standard starting when cold for a 101 with CD strombergs or SU carbies is full choke and hope it is rich enough to start.
    BS and something is very wrong.
    Hot start is foot to the floor.
    Narrogin WA
    I agree with the others about over-richness.
    Another cause is a weak spark, often caused by a dodgy coil, but in your case more likely too much fuel,
    Cheers Charlie
