Results 1 to 10 of 11
Thread: Driveline vibration
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    Driveline vibration
    wife's d1 id developing a slight vibration at speeds above 100kph
    havent been able to pick what it is but it gets worse when you start slowing...
    any ideas?
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Safety Bay
    Uni's or donut if fitted. Pat
    May 2008
    Bundaberg Qld
    I have a vibration in my V8 as well. It does not seem to be gear or revs dependent and generally disappears on throttle lift off. All wheel nuts are good and the harmonic balancer "looks" to be OK. I have crawled under it and rattled uni joints and tailshafts etc. and nothing is obvious although I am yet to check rear gearbox mount.
    Dec 2008
    Geelong
    Quote Originally Posted by pop058 View Post
    With the uni joints, make sure the driveline is unloaded to check play - everything in neutral, handbrake off (chocked of course so you don't get run over). Any load or binding makes the joints feel tight and its hard to determine excess movement.
    Mar 2009
    Uni, Tie-Rod or Tyre Weight missing would be my first go to. Didn't know a D1 could go over 100kph. Unless your wife drives like mine
    98 Defender 110 tdi Boomer
    St Helena,Melbourne
    4.28 MB
    Hub bearing adjustment also makes it vibrate when too lose.
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Moruya Heads/Sth. Coast, NSW
    Inc. first sign of vibration I would do a thorough inspection of all the uni-joints, esp. front T/shaft, because if one fails and the T/S starts flogging around under there the amount of damage can be staggering.
    Second would get wheels balanced and Toe In/Out checked.
    Third wheel bearings, also check rims aren't bent or buckled, Regards Frank.
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    unis all seem fine..... but i havent dropped the shafts...
    ta all...
    Dec 2013
    Kickin about QLD
    I had vibration on the 130. Uni was so buggered it broke a gearbox mount. I ended up doing all the unis (cause they where pretty floppy) and replacing all the nuts and bolts. Drives heavenly now.
    Sep 2009
    If its got the rubber boot on the sliding section of the front shaft a build-up of grease will do it. It plagued my classic when I first got it.
