Results 1 to 10 of 17
Thread: Stihl brushcutter problems
    Central Queensland
    Hi guys
    Recently my ~6yo Stihl FS90z brushcutter has been bogging down even in light grass, and holding the throttle flat after the first 20 minutes or so basically causes it to die right off and stop.
    I've given it fresh air and fuel filters, new spark plug and a fresh fuel mix, but its still doing it, although 10 minutes of pulsing the throttle the last time I ran it seemed to have temporarily cured its woes, but no idea if its going to do it again....
    any ideas?
    Aug 2010
    Sunbury, VIC
    Sounds like the mixture has changed slightly and may be running a tad rich. You should find 2 screws on the carby - marked hi and lo. I'd start by screwing in the hi screw a touch while holding the throttle open to see if it responds better. There are some good on line tutorials on how to tune a 2 stroke engine. Ill see if I can find one I used last time - it worked for me on an old chainsaw I was playing with.
    Sep 2012
    Adelaide Hills
    i concur, play with the high needle a bit.
    good luck
    Central Queensland
    Tried playing with the mixtures, they were wound right up and didnt help the situation when I turned them down....
    Dec 2011
    sydney - pining for the western desert
    I agree with it being the mixtures, but I found it virtually impossible to tune my stihl km90r & ended up taking to an expert. Well worth the expense IMHO
    Sent from my GT-I9505 using AULRO mobile app
    Feb 2014
    Diamond Creek Victoria
    Try taking the muffler off and checking for clogs. Then look at the exhaust port on the motor. Sometimes they get gummed up with soot and will cause all sorts of bogging.....
    Sent from my iPhone using AULRO mobile app
    Jul 2009
    Lake Macquarie NSW
    Does it have the one piece fuel delivery/return black rubber tubing?.
    I had the same issues with mine. Turned out to be a perished fuel delivery tube making the mixture too lean. I ended up just using some aquarium air tubing to replace the inlet/return and have not had an issue since. I was a little dubious about the compatibility of the tubing with fuel but so far, all good.
    Robbo
    Crafers West South Australia
    The one way air inlet valve on the filler cap may be too tight, rubber gone a bit hard. Unscrew the cap for a second while its bogging down and see if it picks up. I had this problem with a new brush cutter recently, I stuck a sharp knife in the valve and reduced its tightness a bit. Works perfectly now.
    Oct 2007
    Wantabadgery, N.S.W.
    mud wasps got into the muffler on mine and made it bog down and hard to start.
    Don.
    Jul 2007
    Quote Originally Posted by Don 130 View Post
    Don.
    I have found the same on several chainsaws and trimmers.
    Quote Originally Posted by benji View Post
    Maybe we're expecting too much out of what really is a smallish motor allready pushing 2 tonnes. Just because it's a v8 doesn't mean it's powerfull.
    One answer REV IT BABY REV IT!!!
