Results 1 to 10 of 33
Thread: Latest navigation disc - is anyone going to bother?
    Nov 2013
    https://www.landrover.whereis.com.au/shopexd.asp?id=33
    Still too expensive in my opinion.
    Jan 2014
    Emu Park
    I just use my iPhone's if needed but I hardly use nav at all maybe once a year so can't see the point of it.
    Sep 2011
    Central Tasmania (formerly Adelaide Hills)
    Update or not? "It depends"
    If there are new roads where you drive and need to navigate or errors, you may get a benefit.
    The "how to guide" is here.
    http://www.aulro.com/afvb/d3-d4-rrs/...maps-my12.html
    Feb 2012
    Wollongong
    Yay for their pathetic belated updated maps ... I may do it ... undecided ... expensive ...
    Adelaide - Torrens Park
    If I could access a disc to make a "backup" from I would.
    Jul 2014
    Launceston, Tas
    How do you know what version you have now?
    Sep 2011
    Minyama
    Quote Originally Posted by BigJon View Post
    Disc is not the issue, you require an activation key generated from your VIN to be entered into the SatNav when doing the update.
    Feb 2012
    Wollongong
    Is that the case with D3 systems ?
    BJM you can eject the disk and see what version it is ((D3), I'm sure there is some other way but that's easy.
    I purchased the disc for my05 a couple of years ago it only has 2008 maps on it. It seems that when Tata purchased Landrover they put future update disc's on hold. Sensis only had one disc left that they found for me. They said that it was now discontinued and Land rover aren't releasing any updates. So it comes as a surprise to me that they have now released a disc that has support for 2005 to 2009 D3, If I am right this disc should have 2014 maps. I may purchase one.
    Mar 2007
    South Arm, Tasmania
    I knew there was a good reason why I didn't tick the "SatNav" option box and bought a Hema instead ..................
    Cheers .........
    BMKAL
