Results 1 to 10 of 12
Thread: Rough Idle with Air Conditioner on TD5
    Mar 2012
    Adelaide SA
    I had a search and there was one for a Puma Defender but there was no fix.
    I have a 2001, Discovery 2, 10P, TD5, Auto.
    Now that the weather has warmed up with the Air Conditioner turned on I have noticed the idle gets a bit rough. Like it misses or stumble about every 10 seconds. Driving and all is well so only sitting at idle.
    Nanocom shows a few injector values changing to large numbers i.e. 7-11 mostly positives from what I can see just as it stumbles. Error code is only the EGR stuck closed as I have removed the EGR.
    Turn off the Air Conditioner while watching the values makes them all settle from -2 to 2's mainly and a smooth idle.
    OK help guys.
    Oct 2008
    Do you have any voltage drop issues. For example is the fuse block under your seat melted where the main power lines feed in? Can you get the same issues with the heated rear screen and lights on etc? The ac draws a fair amount of power so wondering if its a voltage drop somewhere.
    Mar 2012
    Adelaide SA
    Quote Originally Posted by BilboBoggles View Post
    Fuse box under the seat sounds like a Defender thing.
    I did notice voltage was only 13.9 to 14 volts. Air Con didn't seem to make much difference to the voltage at the Nanocom or Aux Battery gauge.
    Jul 2014
    west of Transylvania
    Measure the voltage directly on the compressor clutch's plug(black/green wire is live) while somebody switches on and off the aircon....if it's a noticeable drop when switching on the clutch/compressor might be sticking and the engine must work harder to turn it and that's the reason for the idle thing
    also you can remove the compressor clutch relay(R11) while aircon is on and se if the symptom completely dissapears or not, cos if when you remove the relay everything gets back to EXACTLY like when the aircon is switched off then the problem is there somewhere with the clutch
    mousie Guest
    My rough idle with A/C on ended up being engine mounts as well.
    Mar 2012
    Adelaide SA
    Quote Originally Posted by sierrafery View Post
    I tried pulling compressor clutch relay (R11) and while it was not hot today there was no repeat of the rough idle.
    Looks like I'd better have a look at the Air Conditioner Clutch..
    Mar 2012
    Adelaide SA
    Quote Originally Posted by mousie View Post
    Hopefully not, the right one is new and the left one checks out ok.
    Mounts wouldn't account for the varied Injector values???
    Mar 2012
    Adelaide SA
    Checked the Web and it says the way to check the AC clutch coil is by checking ohms across the coil, should be between 3 to 5 ohms.
    Checking mine shows 4.0 ohms so I hope it means it's all good. So that counts out the AC clutch coil.
    Jul 2010
    Hunter Valley NSW
    Then seizing compressor.
    Excessive refrigerant head pressure.
    Mar 2012
    Adelaide SA
    Quote Originally Posted by northiam View Post
    Did I mention the Air Con works fine.. Tested it on LO and it almost blows ice cubes out the vents..
    Spoke to a Land Rover Specialist today and he didn't think it was a big problem. Like it's not unusual??? Suggested it might be a dirty earth somewhere.
