Results 1 to 10 of 11
Thread: R380 output shaft. Anyone seen this before?
    Dec 2010
    Batemans Bay mostly, and Brisbane
    This is output shaft suffix L gearbox.
    With input gear. Notice the gap at the end? This ends up being a problem when fitting the LT230 box. Input gear is not seating correctly.
    This shaft on the suffix J box just removed from the vehicle. Splines don't terminate and allow the input gear to butt up against the collar.
    Input gear fitting neatly on the shaft- no issues.
    Has anyone seen this before?
    Ideas/Solutions?
    Crafers West South Australia
    Faced with that scenario I'd happily put the input gear into my small lathe and trim the internal spline with a tungsten carbide tipped boring bit. You obviously only need to take off enough to match the curve at the inner end of the shaft spline. It wouldn't significantly weaken the drive.
    Kingston, Tassie, OZ.
    For starters the input gear should be the other way around, and if there is still a problem then you will have to bore the inner splines of the input gear.
    Jc
    Oct 2012
    FNQ
    The gear is arse apeak X2
    Mazarron,Murcia, Spain
    X3 It's so embarrassing isn't it??? Ian ashcroft
    WA
    x4
    If you had the t-case bolted up you would realise the error of your ways...
    X5.
    Dec 2010
    ok kill me now....
    But in defence, when the case was bolted up I did 'try it both ways' and the gear seemed unwilling to home in correctly.
    I should um, stick to my day job then shall I...
    Safety Bay
    You are going to replace the bearing aren't you?.Remember,it's better to ask a dumb question than make a dumb mistake,good luck with it. Pat
    Jul 2012
    Gaborone, Botswana
    Quote Originally Posted by Ian Ashcroft View Post
    Aw, heck, Ian, very few of us are anywhere near as experienced with LR gearboxes as you. Hand on my heart, I could very well have done the same thing in the heat of the moment. Let's all just take a deep breath....
