Results 1 to 6 of 6
Thread: Click Adjuster
    Jul 2009
    S.E.Qld
    Click Adjuster
    Has anybody ever used one of these? Do they work? Are they worth the money? .W.
    Click Adjust Micrometer Tappet Adjuster Valve Tool | eBay
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    interesting tool!
    more info
    [ame]http://www.mossmotors.com/graphics/products/PDF/386-205.pdf[/ame]
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Queensland
    They discussed this on LRSOC a while back.
    Seems you cant do the exhaust valves on S1 engines, with them.
    Login
    K
    Tried a link but it needs you to login.
    The consensus was , most stick to a feeler gauge.
    Jul 2009
    S.E.Qld
    Quote Originally Posted by 123rover50 View Post
    Login
    Thanks Keith ,don't know how I missed that . .W.
    Mar 2009
    Near Geelong, Vic.
    I've got one.
    No complaints.
    Quite speedy when you have to do ALL the settings e.g. after a head-off head-on.
    Normal servicing, I find a feeler gauge quicker because the gaps rarely change.
    If I've got a noisy one, I track it down with my "stethoscope" ( a length of garden hose stuck in my earhole) then use this device to rack it down, while idling, click by click till it shuts up.
    But, as observed, useless on a side valve set up!
    May 2009
    Tatura, Vic
    Never seen this before. Being a retired spanner I have done hundreds probably thousands on tappet adjustments with feeler gauges, even old grey Holden engines, where it was done with the engine running, and all have worked ok.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
