Results 1 to 10 of 12
Thread: REMOVAL OF WHEEL NUT S/S DRESS COVERS
    Southern Cross Guest
    I wanted to inspect and clean up the brake and front suspension and so need to remove the alloy wheels. These are 18 inch rims and the nuts have a stainless steel dress cap that clips over the nuts.
    The LR wheel brace and levers in the supplied bag also have a purpose made cylindrical plastic tool that has an internal lip made to cover the dress pieces and so will click and then hold so the dress piece can be pulled straight out. Unfortunately the tool is broken and is useless. Until i locate another tool, is there a way to pull these dress caps without damaging them? Id like o do this job asap so any suggestions would be helpful.
    Brian
    Dec 2009
    Baldivis WA
    You only need to remove the covers from the locking nuts.
    You may not even still have locking nuts fitted, to work out if you have or not use the normal wheel brace and undo the nuts. If you find any that just spin they are locking nuts and stabbing a screw driver through the end of the cover and then lever it off. Cover will be stuffed, but it will be off
    Bacchus Marsh Vic.
    Each wheel should have 4 standard nuts and one lock nut.
    The lock nut is the only one with a removable dress cover.
    It has a concave dimple in it and the tool is for slipping over it.
    A rag inside a set of multi grips should see this cover come off.
    I took my lock nuts off as I predominantly do off road/touring trips and didn't want the hassles of the lock nut tool breaking on the side of a track somewhere remote.
    If this has been done to your rig there will be no dimples in any of the caps.
    Cheers, Kyle
    The Good Oil.
    When did you last visit?
    I was never able to remove the stainless cap from the nuts other than from the single lock nut on each wheel.
    I might be wrong but I didn't think they actually came off the other nuts.
    2024 RRS on the road
    2011 D4 3.0 in the drive way
    1999 D2 V8, in heaven
    1984 RRC, in hell
    May 2009
    Tatura, Vic
    Quote Originally Posted by alien View Post
    I did the same. But if you do be warned, if you have a vinyl cover over your spare you will not notice that there is also one there. I removed my four from the wheels and ditched the tool not knowing that the spare had one.
    I was 800km from home when I found out.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    May 2008
    Lismore, NSW
    The stainless dress covers are not designed to come off the standard wheel nuts. If you do manage to get them off the wheel brace will no longer fit correctly and will be too loose.
    The locking nuts have the concave dimple in the end and the plastic tool in the kit is used to remove these. If you send me a PM I can send you the plastic tool as I removed my locking nuts and replaced with standard nuts.
    Warren
    Currently Landroverless - Still interested
    Formerly: 2003 D2a Update TD5 Auto. Platinum edition. ARB Bar, 36" LED light bar, cargo barrier, dual batteries.
    Bairnsdale enjoying the rural view no rooftops to see here
    if you use the wheel brace on the lock nut covers you can wiggle them off without doing any damage
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    The Tyre place uses a hook made from an old welding rod, slides down the side and hooks on the lip of the the lock nut cover and pull to remove.
    Arh huh, so that's how it works. Thanks for the replies and thanks to Warren for the kind offered loan of the tool.
    Brian
    Does your vehicle have locking wheel nuts, Brian? If not, leave the covers in place.
