Results 1 to 9 of 9
Thread: Spring suspension bushes - Replacement
    Nov 2014
    Melbourne, Mount Waverley
    I found this on youtube.
    [ame="http://m.youtube.com/watch?v=t0o7WZO-RNM"]http://m.youtube.com/watch?v=t0o7WZO-RNM[/ame]
    I wish I had known about this 30 years ago when I spent a sweaty, knuckle-bruising couple of days removing and replacing all the bushes in my old Series IIa girl, with numerous drill bits and hacksaw blades.
    Has anyone tried this technique? Any other tricks for completing this task?
    Damian
    Nov 2014
    Quote Originally Posted by damiane View Post
    [URL="http://youtube.com/watch?v=t0o7WZO-RNM"]
    Damian
    Can someone please advise what I am doing wrong with the hyperlink. I can't get it to be a live link and I think I should be able to do so. Thanks.
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    There you go. . Copied link, then clicked the internet icon thingy - the globe on the toolbar, then pasted in there.
    [ame=http://youtu.be/t0o7WZO-RNM]Land Rover Series 3 - Changing Leaf Spring Bushes - YouTube[/ame]
    Homestar's Avatar
    Aug 2010
    Sunbury, VIC
    He made that look easy. I'll be doing mine soon, so we'll see if I can replicate that.
    East-South-East Girt-By-Sea
    1.20 MB
    Try not to replicate everything, he chokes the hammer rather a lot.
    Also he doesn't show lubricating the pin liberally with grease when you put it in so that it makes it easier to get out next time.
    Apr 2014
    Blair Athol, Adelaide South Aust.
    That looked so easy. I wont be putting my bush replacement off now....hehehe. not sure about the front chassis bush tho,
    Cheers Rod
    Sent from my GT-P5110 using AULRO mobile app
    Aug 2011
    Bacchus Marsh
    Bacicat
    Give me a shout before you attempt it. I have a gadget.
    Aug 2011
    Bacchus Marsh
    Oh and I tried that - you might get lucky. I didn't. Wedges or not, mine would not shift.
    Narrogin WA
    It is a good idea to run a small flap-wheel for a drill, through the spring-eye to clean off the rust and use anti-seize grease as Diana suggests, on the bolts and threads as well.
    That was the easy bit - the one in the chassis is the nasty one! I usually burn the rubber out and cut the outer sleeve with a hacksaw,
    Cheers Charlie
