Results 1 to 10 of 19
Thread: Size of nut.
    Jan 2014
    Melton, VIC
    Size of nut.
    Ok, looking for some info here, am taking apart the axles and I have come across a snag, there's a nut the size of my head in there holding things together and I have no spanner large enough, would anyone know the size of this nut so I can find me a large enough socket?
    It's a series 2a front axle, just after the castle nut on the shaft there's a giant one held tight with a bent washer, sadly due to the rain I have no picture of it but am figuring there can't ge that many giant nuts on the axle lol.
    Thanks in advance
    ~Dan
    Jan 2013
    Penrith
    Ok I may be well off the msrk here but it sounds like the hub nut your talking about, while I have no experience with series vehicles, on a D1 that nut is 52mm
    smurf village
    JDNSW's Avatar
    JDNSW is online now RoverLord Silver Subscriber
    Since the Series Landrover, and the Jeep that standardised on this nut size, used Imperial measurements, the size is actually 2 1/16" - but they are commonly sold as 52mm.
    Jan 2014
    Melton, VIC
    Thanks all! Shall trawl the aisles at the local hardware places for something this size
    Narre Warren South
    I'm sure I've seen a 54mm tube spanner in Autobarn (it was a cross between a tube spanner & a socket, bar with 1/2" square hole welded across one end). Must be for a Japanese 4WD but is close enough and won't cause damage to the nuts.
    Colin
    '65 Series IIa Dormobile
    '70 SIIa GS
    '76 SIII 88" (Isuzu C240)
    '81 SIII FFR
    '95 Defender Tanami
    Motorcycles :-
    Common to the front axle of the Blitz and Ford V8 sump plug too.
    Aaron
    JDNSW's Avatar
    Quote Originally Posted by Aaron IIA View Post
    Aaron
    And early Landcruiser and probably Patrol and other Jeep knock-offs.
    Jeep use an eight sided nut, the same as the rear of the Blitz.
    Aaron
    Kiwiland
    The rrc and disco use a tube spanner the same size as hot water cylinder elements. Do you know any sparkies?
