Results 1 to 3 of 3
Thread: Fridgie question
    May 2006
    Southern Wimmera.Grampians
    Fridgie question
    Question for the fridgies, if one was to use this with, say a 2 or 2.5 split system, inverter type condenser unit, would it drop a 2.4x2.4x1.2 cool room to +2 deg.
    Image not available Photos not available for this variation <style type="text/css">.vi-hide-mImgThr {display: none;}</style><img id="icImg" class="img img500" itemprop="image" src="http://i.ebayimg.com/00/s/Mzc1WDUwMA==/z/Fx4AAOxyVaBS6JKj/$_12.JPG" style="" clk="" alt="Unit-Cooler-Evaporator-HEJ-3D-1-7KW-med-temp" />
    Have one to sell? Sell it yourself
    Details about Unit Cooler Evaporator HEJ 3D 1.7KW med temp
    Feb 2012
    Cleveland
    Nup..... The 2.5Kw Split Unit you mentioned is not designed for the suction temps needed........ forget it.... wrong refrigerant most likely as well
    Brisbane,some of the time.
    A 1.5 to 2.0kw refrigeration unit(at -5 SST) is what you need,as others have said,forget the A/C unit
