Results 1 to 8 of 8
Thread: Railco to bearing conversion
    Apr 2014
    Blair Athol, Adelaide South Aust.
    Hi everyone, just wondering if anyone has converted s2a from railco to bearings at the top swivel housing?
    Cheers Rod
    Sent from my GT-P5110 using AULRO mobile app
    Oct 2007
    wetherill park
    Not a 2 or 2a but I had my s111 converted made steering noticeably lighter
    Only question is why would you want to do this?
    Apr 2014
    Twas just a thought. I have a few now and then. Would like lighter steering tho. Think I read something on a pommy forum or might have been a yankee forum. A one liner I think, it was mentioned in a sentence somewhere. Caught my eyes.
    Cheers Rod
    Apr 2014
    Quote Originally Posted by THE BOOGER View Post
    Im about to put discs on my 2a with new swivel housings. Was wondering if it was possible. Any other info available on this conversion???
    Thanks in advance.....
    Cheers Rod
    Oct 2007
    wetherill park
    Not sure about that but Cooky on this forum has a disc upgrade he markets he would be able to say for sure
    Lack of friction damping at the swivel is likely to result in wobble problems. It won't necessarily if everything is just right. If the aim is simply to reduce steering effort, you can simply reduce the preload, but expect to have to adjust it fairly frequently.
    Main way to reduce steering effort is to ensure you are not using wider than standard tyres, and that tyre pressures are at or above recommended. Assuming of course that relay damping is correct; seeing that most of the frictional damping is from the steering relay, changing the swivel damping will make very little difference to overall effort, even if it is reduced to zero.
    East-South-East Girt-By-Sea
    1.20 MB
    1948 Land Rovers had tapered roller bearings top and bottom but no steering damper, these were changed to cone and cup then later railco bearings by Series IIa.
    Range Rover have had tapered roller bearings top and bottom and a steering damper from day one.
    If you ask Cookey he will tell you to convert as it is something that he has done on his own vehicles.
    The down side to tapered roller bearings is if you spend a lot of time on corrugated roads you will find brinelling of the bearing will occur. However these days very few of us spend a signifficant time on corrugated roads.
    Diana
    BTW: I was looking at Cookey's first batch of 20 finished disk brake calliper brackets yesterday, he was in the process of machining hubs and rotors when I last saw him on Sunday.
