Hi Will and not a bad accomplishment.
If you need to get any more wires and/or cables into the cab from the engine bay, there is another, slightly smaller hole in the auxiliary battery compartment.
The second hole will accommodate up to two 6B&S cables and the hole is located up behind the accelerator pedal.
It is hard to find and is really only accessible in D3s and early D4 models.
