Results 1 to 10 of 12
Thread: Prawn Trawler Refrig Regas
    Oct 2012
    FNQ
    Just read an ABC article where the Cairns prawn trawler fleet are about to trial a new refrigerant gas .Going from R22 at up $160 a KG to some gas at $35 kg.They didn't say which gas but would be Hychil or similar at that price I would imagine.I am really happy with the 300g of bang gas in my Defender system but not to sure about 140 kg in a boat As I am about to charge my yacht freezer systems any fridge mechanics thoughts appreciated
    Noel
    Feb 2012
    Cleveland
    Link to the article would be good.......... As far as your yacht goes, all depends on charge qty and future leaks developing doesn't it, are the systems DC hermetic or open drive from Aux engine, is there a chance the refrigerant could leak and accumulate in the bilge? If no leaks down the track should be no problem.
    I remember seeing a 4 CYL Perkins destroy itself from ingesting R12 years ago............shudder to think what would have happened if it was a propane based refrigerant
    May 2003
    On The Road
    You asleep out there Ean?
    Queensland
    Our eutectic system in the yacht was R 12 but we had a propane stove and oven.
    I imagine you have too so Hychill in the reefer should not be any more of a problem.
    Put a gas detector in the bilge or if still concerned contact Hychill direct. I found them very helpful.
    I put it in the Rangie and its all good, and I will put it in the RedDot in the disco as soon as these adaptors for these bloody R-134a fittings arrive.
    Ean Austral Guest
    I know there are 3 or 4 different gases being trialled. R22 is being phased out so the price reflects that. It is used because you can achieve very cold temps with it.
    My understanding is a lot of things need to be changed when changing from R22. Expansion valves need replacing and believe even a certain type of oil is needed with the new gases.
    What was used in your yacht? Think you need to find that out before you go much further.
    I will speak with our fleet engineer and see what they are trialling in the fleet.
    Cheers Ean
    Oct 2012
    FNQ
    Thanks to all sorry no good with links My yacht comprises two separate systems 1/ a engine or electric driven open Bock compressor.The other a semi sealed unit which I would be happy enough using Hychill but not so sure about the Bock .The gas alarm has 2 sensors but evacuating the bilge would be a bit nerve racking in the event of a leak As the system is new any suitable gas would be OK .The fridge is separate again
    Thanks Noel
    Gold Coast QLD
    Try the new drop in replacement for R22 called SP22. I sell a lot of it and it works very well. You can top up existing R22 systems, retrofit systems to a full charge of SP22 (80% of R22 charge) as it runs on POE and mineral oils and it is about 1/3rd of the price of R22. Best of all, it don't go bang like a hydrocarbon
    1964, S2a SWB "Ralph"
    1977, S3 SWB "Smeg" (Gone)
    1996 D1 300tdi auto (Gone)
    1973 Rangie Classic (Gone)
    2012, 110 (Series 12) Puma "The Tardis"
    1962 109" Tray Back "Ernie"
    1998 D1 300tdi (Dizzy)
    2017 Kawasaki Versys 1000
    You must now cut down the tallest tree in the forest... With... A HERRING!!!!!
    Oct 2012
    FNQ
    Quote Originally Posted by ezyrama View Post
    Sounds good but with all the licence hassles I guess
    Gold Coast QLD
    Yes, you will need an arctick licence to purchase
    Brisbane,some of the time.
    Quote Originally Posted by Kev the Fridgy View Post
    A real worry.
    I used to do heaps of trawlers in the good old days in Gladstone.
    Looking for refrigerant leaks with a bildge full of freon was fun
    And not good for the health.
    Seems to be heaps of r22 around,mainly coming from decommissioned plants.
    We use it like water,but haven't bought any for ages
    On to r32,anyone checked out toxicity,they recon once it is hit with the oxy torch,is way worse than the old phosgene
