Results 1 to 9 of 9
Thread: EAS valve block diagram - thanks Paul
    Dec 2012
    Dubai
    Hi All,
    I got stuck with my valve block overhaul and was saved by Paul's schematic:
    https://www.dropbox.com/s/7k9yv70gi2...5.pdf'dl=0
    I had swapped solenoids 6 and 7 .....
    Thanks Paul - I was able to follow the wires from solenoid to multiplug and correct the error.
    I hope it's ok top post the link here, if not, please delete it.
    Paul,
    would you like to add it to the AULRO Files section?
    May 2008
    Paul,
    Sure Ron, use the copy in Spiggy's post, or the source at
    [ame]http://hardrange.com/downloads/manual/EAS-ValveBlock-v1.5.pdf[/ame]
    I may yet update the EAS Valve Block Rebuild Guide over the Chrissy break, and will re-home the diagram from hardrange.com to paulp38a.com.
    hardrange.com isn't going anywhere yet, but I won't be maintaining it much any more, just keep security patched and host updated.
    Cheers, Paul.
    Poland (I kid you not)
    I used Paul's diagram when I did mine. Got me out of a right pickle.
    Don't know if I thanked you at the time, so Thanks Paul!
    Oct 2008
    awesome diagram, will help me when I do my rebuild of valve block.
    I sprayed soapy water around looking for leaks and I have leaking seals on the dryer and I had bubbles coming out of the top of the valve block between the non return valve and main block and also had bubbles come out of the exhaust silencer, so I think I need to replace orings.
    Question is what size orings are they or where's the best place to get a kit made up.
    regards
    Shane
    Jul 2014
    Shane' the kits consisting of all o rings and diaphram are available on e bay.... I Would post a link but can't seem to get it on........ I Am sure someone will for you.....also paulP38a has a great. Step by step write up
    2000 4.6 HSE Alveston red
    2007 307 xse peugeot
    1974 xj6l jaguar
    Jul 2014
    I think a good supplier is Scotty at WWW.BECMDOCTOR.COM........
    1974 xj6l jaguar
    Oct 2008
    ive cheched it out further and its only leaking from the tank return line and my front left airbag at the valve block
    does anyone know the sizes of these o rings
    im guessing that inside diameter would be 8mm and 6mm but I need the thickness of both
    ive been to 3 range rover specialists and none of them know the size, just get a kit off ebay they say.
    problem is the kits in England and I need to get mobile ASAP.
    thanks
    Hey Shane,
    Sometimes the pipe gets scored and then leaks, just pull it out and have a look.
    The other thing to get is a set of schrader valves, you can disable the EAS and then pump each corner manually.
