Results 1 to 10 of 15
Thread: Lower wishbone time. Advice stories wanted please
    Jan 2010
    tom price the pilbra, west aust
    So got a lower front wishbone bush needs replacing.
    Pretty sure the previous owner had the bushes replaced with poly. Probably why they haven't lasted. I want to go back to rubber bushes.
    Should I replace the whole wishbones or by the kits to replace just the bushes?
    Do I need to deflate the springs to make it easier? Tips tricks etc most welcome.
    06 disco
    Kingston, Tassie, OZ.
    Just fit complete wishbones, if you are approaching 90,000km then you'll need ball joints soon anyway.
    Jc
    Ean Austral Guest
    Quote Originally Posted by ade View Post
    06 disco
    I found there wasn't much difference in price to do the whole wishbone especially when you factor in time to remove/replace the bushes and the ball joint.
    I did a tutorial on when I did mine, should be in the projects section. Was about 16 months ago now but it will still be there. Not a hard job just make sure that for a few days before you do it you spray the main bolts with CRC or similar and hope it works its way in, makes the job of undoing them heaps easier.
    Cheers Ean
    Mandurah WA
    I am waiting on some lower control arms from Advanced Factors to replace those on my D4.Have ordered a full kit with RRS arms, with the larger ball joint and will replace the rubber bushes with Super Pro polys.Hopefully will not have to cut the old arms off and will be able to fit the rubber bushes to them as spares.Will give it a go next week.
    Assume you have a D3 003DK DISCOVERY 3 AIR SUSPENSION FRONT LOWER ARM FULL KIT FOR BOTH SIDES Freight 90GBp
    Apr 2010
    Northern Victoria
    Replace the complete arm. I replaced the bushes and ball joints only in order to save on freight. However did not last (12000 kms) and one bush failed. Have now replaced complete arms. Problem was that the bushes were not a proper fit in the old arms. Freight was same cost of the arms (75 pounds each)
    Ivan
    Apr 2014
    Central Coast
    Is this a known failure point? Seems 90k is fairly short lifespan for something as major as lower control arms.
    Feb 2012
    Wollongong
    Heavy vehicle with complex car like suspension ... personally I think they should be noted (like a few other things) as a service item. Mine is almost at 150,000km and I'm on my third set of LCA's ... its not the arm that fails, but usually the innermost bush goes (as it takes a pounding in normal driving) and it is easier/almost as economical (in my opinion) to just change the whole arm and that way you get new bushes and balljoints in one fell swoop.
    Sep 2014
    Baldivis WA
    D4 Front suspension / Wishbones
    I was looking for a post like this - during last service at SLR (Perth WA), they told me that "the bushes in the front suspension are wearing / worn and will need replacing soon" SLR quoted this at "about $1600" .......
    I do have some noticeable steering wheel shudder at 100-110kmh and especially when light braking / washing speed off from cruising speed. Under heavier braking, it disappears completely. No pulsing of brake pedal noticed at all.
    I am putting it down to wheels needing alignment (Am aware of the special way it needs to be done) and worn (H/T) tyres that are on the car as I have bought it.
    I was also of the same opinion that at ~90K kms (at the time of the service) seems a bit odd that these items are already worn.
    1. Don't feel like shelling out 1600 bucks for just a new set of bushes.
    2. Would rather replace entire wishbones and ball joints if that's easier, but after having a look underneath, cannot see any obvious wear to the ball joints (no torn boots or grease spilling out, no free play in the arms etc.)
    Any ideas or pointers would be appreciated.
    Just wondering what the real issue
    Safety Bay
    Look at DLS Spares,$150 a side. Pat
    NSW SW Slopes
    Quote Originally Posted by IvanR View Post
    Were they genuine or after-market bushes?
