Results 1 to 10 of 26
Thread: Control Arm Bush Replacement
    Aug 2009
    Question Control Arm Bush Replacement
    The Lower Control Arm bushes on my D3 need replacing- can hear it knocking over bumps etc. They have done 125,000klms.
    Does anyone have experience with getting them replaced with Polyurethane Bushes (e.g. Pedders) vs. the original rubber type?
    Also, is it better to just buy the whole arm complete with bushes & ball joint($308 non genuine) rather than replacing the bushes.
    I suspect the Polyurethane bushes may give a harsher ride.
    The LR dealer quoted me $1,900 for the job, but that sounds outrageous.
    It seems like its a pretty normal for these to wear out.
    thanks in advance for any comments.
    Jul 2014
    I had to do the front ones on my D3 cost $800-$900 done by my mechanic. A friend put in the poly bushes he had them taken out the ride was so harsh even with the awesome air suspension.
    Dec 2013
    Kallaroo, WA
    If you have a decent vice, a butane torch, and an air chisel you could quite easily do them yourself in around 3 hours.
    Ive done 4 sets now and its a job that any level headed DIYer could do.
    Mar 2013
    May 2013
    Port Melbourne
    Quote Originally Posted by relatively normal View Post
    What is the butane torch for?
    PERTH WA
    Quote Originally Posted by BSM View Post
    Lighting your cigarette after your done?
    Dec 2013
    Kallaroo, WA
    The torch is for heating up the arm with the old bush in so it slides out easier with the air chisel.
    All in all it should take around 45 mins to remove both arms, 15 mins to remove the old bushes and 20 mins to fit the new bushes (without a press and with a strong arm). Then another 45ish to get them back in the car. Plus a bit of time scratching your head and taking a break.
    Mar 2011
    Cairns
    Quote Originally Posted by wyperfield View Post
    Are you sure it's not the ball joint? That seems to be the common the fault with the 'front knocking' sound. Had mine replaced recently, believing it was the bushes, but found out it was the ball. For the price quoted you might find they are replacing the whole arm. Ball, bushes and arm all new, just as quick to do once you get things out.
    Kingston, Tassie, OZ.
    Don't waste your time doing bushes at 125k, ball joints are also going to be munted. Whole arm replacement is the most effective and economical. OEM arms around $400 each, and allow labour to fit and wheel alignment.
    Jc
    May 2014
    Point Cook, VIC
    Jc
    Is it correct that the OEM arms come with larger ball joints compared to the early D3's? Would you then expect a longer life the second time around?
