Thread: coolant pump weeping v8
    Feb 2011
    Lockington, Victoria
    Coolant pump is weeping from the small hole on the right hand side above the inlet. Is this an easy fix or do I need a new pump?
    Apr 2010
    Lower Hunter Valley NSW
    New pump. That little hole gives you a heads up that the internal seal is on its way out.
    May 2009
    Tatura, Vic
    If it is the hole in the pump itself a new pump is needed. The idea of this hole is for when the seal leaks, the coolant will run out the hole, instead of into the pump bearing.
    Dave.
    I was asked " Is it ignorance or apathy?" I replied "I don't know and I don't care."
    1983 RR gone (wish I kept it)
    1996 TDI ES.
    2003 TD5 HSE
    1987 Isuzu County
    Feb 2011
    Thanks Guys, bugga just did head gaskets, pump was fine before that.
    Vendor
    Subscriber
    Jul 2012
    Tecoma Vic
    Check your viscous fan coupling also, they also go and cause new fitted pumps to have short life spans.
