yes, if youre thiking about what I think your talking about these are the bearings the rocker arms run on.
you may still have them but they will have changed colour and will appear to be just part of the rocker itself.
its a bit of a stretch of my memory but I think the tdi rocker shaft will drop in and do the same job for you and the rockers to suit are a fit as well. but its been a very very long time since Ive done a rocker shaft on a series engine, normally they last pretty well and just require the arms rebushed.
I cant remember and dont have my series manuals but there is also a washer like bush that sits between the springs and the rockers as well as the rockers and the towers, its paramount that these be fitted if you want to have reliable oil pressure throughout the head as they seal up the rocker arms on the sides.
if you can upload a photo of the bit you're talking about instead of me rlying on memory I might be able to give you more definitive advise.
