Results 1 to 10 of 18
Thread: upgrades....
    Jul 2011
    burpengary
    upgrades....
    Hi all, well I've made a few changes to my rangie. The new air( trumpet style) cleaner should be a bit stronger if the old girl backfires again. I have also been having a dead battery after a few days parked and am assuming its another small leak in the EAS. I installed a kit to allow air to be pumped in at a servo or by remote airpump and all was perfect for a while and i drove it to work and back for a week, 500 k's or as and i am guessing the movement has loosened something. i went on Range Rover P38 EAS modifications improvements and tips learned by experience by ownership. , and did this little mod to stop the EAS constantly trying to level itself . i also wired in a 12v fan from a computer and screwed it to the top of my fusebox cover with a few holes drilled under it to try and keep the temp down a bit...might not do much but we will see. All seams to work well. Now it sits up at high and standard height overnight with no sagging or dropping. The problem, if it is one is that as soon as i turn the key on..it lowers all the way to lowest position. As soon as i push the height to rise it does so immediately. Does this tell anyone where my leak may be? or even if it has one...
    Jul 2011
    burpengary
    Last night I went down to shed after about three days to find rear of car evenly lower than the front. With the self leveller isolated now I thought I might find one corner down , but both rear down and even puzzles me. I start the car and it drops straight to entry level, if I hit standard it rises straight away. If I park for more than 15 mins on uneven ground when I start again it wobbles around until it finds a level.I will try a soapy water spray again to see. I finished the new air intake...seams to be fine.
    Feb 2013
    Gosford, NSW, Australia
    Quote Originally Posted by deano2469 View Post
    i also wired in a 12v fan from a computer and screwed it to the top of my fusebox cover with a few holes drilled under it to try and keep the temp down a bit...might not do much but we will see. .
    I thought about this but decided the danger of water ingress and consequent damage is worse than the long term effects of the heat.
    Steve
    Sorry in advance (especially to Ron) for the crap wording/grandma(!) of this response... but...
    Isn't the fuse box issue a result of the "too short" overflow pipe on the expansion tank causing premature aging on solder joints and/or the over use of the heater relays due to blocked pollen filters causing clogged blend motors to be over stressed and/or jammed?
    Hoo-Roo,
    Dave.
    I sorted the overflow pipe issue by simply poking the end into a small (200ml) plastic drink container. The bottle stays upright ...doesn't need restraining. When the expansion reservoir is filled to the correct level when cold, it should not overflow.... if it does, suspect head gasket leak.... so there should be no fluid in the container... makes excellent visual check point
    Feb 2013
    Quote Originally Posted by DT-P38 View Post
    It seems to be a combo of those issues and especially RL7, I am looking at replacing that standard relay with a heavier duty one which should dissipate the heat a little better.
    Also thinking about other ways to ventilate the box without compromising it's seal
    Steve
    May 2013
    Bittern Vic
    I had a bit of trouble with the suspension on mine being unlevel and changing each time I parked it, I did the recalibrate the height sensor thing and all is much better now, the car sits level when parked and when in use.
    Jan 2012
    Bendigo
    A few years ago I externally mounted rl 6 and 7. Used 150 amp hella relays, and mounted them next to the ecu box under the battery cover. It was a second hand relay box though, so it's hard to make any assessment on it. They sure do get hot though, especially with the fans on high!
    Sent from my GT-I9305T using AULRO mobile app
    Jul 2011
    burpengary
    Hi all, some good ideas boys. The fuse box seal was never that good anyway on mine so assumed it was heating up from relays etc. Might not work but will test temps soon. The self levelling thing works great, except for the dropping to entry each time i start the car, resorted to putting it down first. Now, has not stopped the battery going dead in three to four days. Brand new battery mind you. I leave the key on the dash down in the shed so its near the car when i want to move it out of the way of the mower...will leaving the key in the car be causing the car to be alert for any reason, I've heard about rf frequencies and stuff but should i take key away from car?...not sure at all now why this is happening.
    Also, I have put an add in everything else for sale for some landrover sandals, they are on gumtree too, bought new but too big for my feet.Check it out. Hoges, I will try the bottle idea as well, anything to help.
    Jul 2011
    burpengary
    I just realised i have left my ELM27 bluetooth plug in the plug hole and would have been there for weeks and might be cause of flat battery...anyone confirm this?
