Why???
LED trailer light issues???
Andrew
Is there a simple electronic way to disable the rear parking sensors on a D3
Why???
Andrew
DISCOVERY IS TO BE DISOWNED
Snow White MY14 TDV6 D4
I wish I could disable mine at times parrticularly in long grass.
I don't think there is any way to do it.
Unlike the D2.....
Yes I'm sure there is a fuse behind the glovebox which is for the sensors. I'll let you know tomorrow which one.
2014 SDV6 HSE - LLAMS, Tuff Ant Tree Sliders, Tuff Ant 18" rims, Nitto Ridge Grappler tyres 265/65 R18, Custom Lipo4 battery, Custom Drawer storage system https://www.box.com/s/jem0ilac3cner2mexq64
My mechanis disabled mine when I out the RWC and Mitch hitch on, but I don't know how he did it.
 Fossicker
						Fossicker
						You can disable the car default setting, however you need a nanocom or similar tool to make the change.
I had some success with covering up the two inner sensors with clear floor protectors you can source from a hardware shop. The LHS one I cut in half to mask the mitch hitch and the RHS one fully covers the sensor to mask the RWC and hitch.
Seems to work for me reasonably well.
Passenger side fuse box behind the lower glovebox.
Remove fuse 36: Tyre Pressure monitor / Park distance control.
Give that a try, or if you want make up a remote switch with an inline 5amp fuse so you can enable/disable easily.
How do you get to this? Do I need to remove glove box?
[SIGPIC]
2012 LR Defender 90 (BERT) Gone
2012 Husqvarna WR 300
2014 FPV F6 Gone
2005 D3 SE V8
2011 D4 V8
2016 Moto Guzzi California Audace.
I found out how to remove glove box and removed the fuse but that didn't stop switch on dash flashing. Sometimes it cancels by pressing it and sometimes it doesn't.
[SIGPIC]
2014 FPV F6 Gone
2005 D3 SE V8
2011 D4 V8
Definitely fuse 36, note the label is above the fuse.
Worked on a 05 D3.
Check legend on back of glove box.
