Results 1 to 10 of 13
Thread: Converting 1954 CVs to earlier Tracta Joints - Whats involved?
    Sydney, NSW
    Hi all,
    I recently started to partially strip my front axle to install 11" x 3" brakes from a 6 cyl.
    Whilst I was elbow deep in grease I thought Id go the whole hog and replace all bearings and seals...
    Now I have the half-shafts out Id like to replace them with earlier tracta-joint variants so that I can use the permanent 4WD from my R380/LT230 combo.
    I know its possible to swap CVs for tracta's but I don't know what else is involved. Is it a straight swap or do I need different seals, bearings etc etc?
    Anyone know where I could drop on a pair of good tracta-jointed half-shafts?
    Thx
    Jon
    Regards,
    Jon
    Uni's and CV's
    A couple of things;
    The inside half shaft for the 80" Tracta joint is located by a ball bearing and this is in turn fastened by sleave that is shrunk onto the half shaft and to service this, a workshop press of twenty tonnes is required to dismantle the shaft from the swivel pin ball housing.
    To take the diff out of the front of a 80", the flanges at the inside of the swivel pin housing's to the diff housing has to be separated, to be able to withdraw the axle half shaft's from out of the diff centre.
    The 1954 to late Series 3 had Universal Joints in their front axles, not Constant Velocity Joints ( CV's ), but I know what you are getting at, that is that kick in the steering experienced when powering on full lock.
    I don't know of any modification that allows a Discovery or similar, CV to be fitted into the early swivel pin ball housings and I would like to know if this has been done?
    The Stage one had CV's, but the diff housing is longer than a Series 1 , so the whole front axle assembly would need to be changed over.
    Last edited by wrinklearthur; 1st January 2015 at 08:09 AM. Reason: add the bit about the stage one
    WA
    Quote Originally Posted by wrinklearthur View Post
    Maxi drive used to machine the inside of series chrome balls to allow 110 AEU2522 cvs to be fitted.
    Worth noting that there are plenty of 4x4s which were constant 4x4 with ujs.
    Sydney, NSW
    A couple of things;
    Thanks Arthur.
    Apologies for using the word CV, I did of course mean UJ. So I guess my question is how easy is it / is it possible to replace my 1954 86" UJ half-shafts with tracta-joint half shafts out of an 80 whilst retaining my diff.
    Thx
    J
    Regards,
    Jon
    Timj is offline Wizard Silver Subscriber
    Brisbane,Qld.
    The tracta joints had the different bearing on the diff side and they also had a brass bush inside the stub axle. I believe this was because they needed to be kept in place more solidly than a universal. While they are a fascinating joint it would be difficult to find one in really perfect condition as it is now sixty years since they were used. However to answer your question there is no good reason why they could not be swapped in as long as you use the right bearing. The later swivel housing actually has more room so won't be a problem.
    TimJ
    Gumnut - 1953 Series I 80"
    Poverty - 1958 Series I 88"
    Arnie - 1975 710M Pinzgauer
    JDNSW's Avatar
    Quote Originally Posted by Timj View Post
    TimJ
    Correct - the universal joint, and the later Rzeppa joint are self aligning, whereas the Tracta joint (actually, when you analyse it, really a double Cardan joint) requires external alignment.
    While both types of joint date from about the same time (Tracta 1926, Rzeppa 1927), the Tracta joint remained the CV of choice until the late 1950s. The reason for this is that the Tracta joint is easy to manufacture, being tolerant of inaccuracies or wear, and because of the large bearing area, not very demanding of materials, whereas the Rzeppa joint is very difficult to manufacture as it needs to be very accurately made, and heat treatment, materials and lubrication are critical.
    This suggests that manufacturing new Tracta joints should not be beyond the capabilities of any modest engineering workshop that seriously wants to do it.
    WA
    However it would probably be cheaper and easier to get the balls and stub axles machined to take aeu2522 or rrc cvs. You would also have off the shelf replacements.
    Barry at hitough probably still does this, and can supply the right inner halfshafts.
    Sydney, NSW
    I spoke to Barry at Hi-Tough and he advised he can't do the machining and further suggested that Id be OK to keep the UJs.
    He said (similar to my initial thinking) that because the LT230 has a centre differential then there would be no transmission wind up and so the UJs would be fine, i.e. no need to replace with Tracta's or the later CVs.
    Also, not sure if it complicates things or makes things better for me - my front axle has free wheeling hubs fitted. This means that I either need to engage them all the time to get movement, or keep them dis-engaged and engage the centre diff to allow forward movement.
    For now I'm going to leave the UJs in place and see how I get on.
    Thoughts please.
    Thx
    Jon
    Regards,
    Jon
    WA
    Quote Originally Posted by Yorkshire_Jon View Post
    Thoughts please.
    Thx
    Jon
    Most LR people don't think you can have constant 4x4 with UJs, however Jeep (and others) did it for many years. You may get some slight feedback in the steering wheel on tight corners, but that is all.
    East-South-East Girt-By-Sea
    1.20 MB
    You could always fit a stage 1 front axle and SII/SIII 88" rear axle, which will also give you a little better turning circle) . Or you could talk to Barry about making up some short S1 length halfshafts for the Stage 1 swivels, these will bolt up to your S1 housing.
    If you need some 80" front axle components, I took a heap of them out to storage at Maralya I'm sure we can come up with enough bits.
