Results 1 to 10 of 28
Thread: Any Pro welders out there?
    May 2003
    On The Road
    Question Any Pro welders out there?
    Found these today,,
    I will be getting them fixed professionally but was after advise on strengthening the areas,,
    The external shot is where the front bin attaches so I think the frame itself is not cracked,, the other two are the same part of the frame on each side.
    South East Tasmania
    Where are you now Pedro?
    May 2003
    On The Road
    Hi Arthur
    We are at Tooradin again,, the local boat builder is coming to take a look and is sure he can fix it. I'm not exactly sure whats holding it to the car at the moment,,,
    South East Tasmania
    Oh. you are not longer in the apple island!
    Make sure that there are not other cracks due to stress in another parts of the chassis.
    it will be good idea to reinforce the weak points and find ou why the weld failed. have you put to much load on it?
    Jul 2009
    Lake Macquarie NSW
    Pedro.
    That's no good at all mate. Especially when away touring.
    It's going to difficult to repair properly as you won't be able to access the top of the welded joint without separating it from the floor of the van. Best option here is to weld up the crack best as possable then gusset the join with some flatbar (say 3mm) on 3 sides. That should keep you out of trouble until a more permanent repair can be done.
    Robbo
    Jeez, Pedro. Not looking good for the lap of Oz!
    Is that dappled surface the van floor? If so, it looks like the frame has bent and cracked. Maybe the weld under the floor hasn't yet cracked.
    May 2003
    On The Road
    Morning Ron
    yea, my first thoughts were unprintable,, then the next thought was
    hey, no one said it would be easy---
    but as the song says,
    Time is on our side
    May 2003
    On The Road
    You still there Robbo?
    any problems welding with the storage batts connected?
    South East Tasmania
    I would disconnect all the earth terminals to the body.
    What Arthur said.
