Results 1 to 3 of 3
Thread: 2009 130 Defender-Starting problems....
    Mrkk Guest
    My 2009 130 Defender is playing up on start up, this has gradually got worse,
    the starter motor is firing for one brief crank then nothing..
    I have gone through a process of elimination and it seems to be the barrel,
    if i wiggle the key with pressure on one side it fires the engine up.
    Does anyone have advice on a diy fix to this problem???
    Jan 2011
    Caroline Springs, Vic.
    Landrover have had issue's with the ignition barrel on the puma, I think there was even a recall notice. Slightly different issue though as the barrel was jamming causing the starter to over run, and hence failure of both. I think Samblers had this happen at the beginning of this year.
    Just do a quick search under "ignition barrel" and it should answer some if not all of your questions.
    Here's a few to get you started.
    Cheers, Ian.
    2010 Puma - sign of impending problems?
    Puma ignition switch on its way out?
    PUMA WONT START
    Deja Vu (LR ign Barrel, switch and steering lock)
    Mrkk Guest
    Thanks for the info, all is welcome.
    I have sprayed into the barrel WD40, thought I would give it a try before I give up and throw money at it, this seems to have done the trick, after a few more cranks of the key and a lot of carbon colour deposit it has started to fire up straight away.
    Not sure if this is a long term solution though. I will see how it fires up over the coming days.
