Results 1 to 9 of 9
Thread: cutting sidewalls off truck tyres
    May 2006
    Ulverstone,TAS
    Hi guys,
    Am wanting to cut the side walls off some truck tyres for garden beds.
    What would be the best tool(s) to do this.
    Thanks in advance.
    2014 Freelander SE TD4
    2003 Range Rover TD6
    92 disco tdi manual sold
    95 disco tdi auto gone
    May 2008
    Bundaberg Qld
    Recip saw
    RIVERLAND, SOUTH AUSTRALIA
    Borrowed or hired
    WA
    Quote Originally Posted by disco gazza View Post
    Hi guys,
    Thanks in advance.
    As per pop's post, a reciprocating hacksaw. What the US websites will call a sawzall.
    South Sydney
    I have used a few things...
    -Angle grinder... works, but don't try it unless you really have to
    -jigsaw... works well with the correct blade, most accurate I have found.
    -reciprocating saw... good for straight lines, inaccurate as all hell, do it this way if you don't care how it turns out.
    Mar 2007
    Warwick Qld
    Haven't tried it personally but a mate reckons it's easier if you have a hose dribbling on the cut. Apparently water is the cutting compound of choice for tyres.
    Sent from my Nexus 7 using AULRO mobile app
    1999 Disco TD5 ("Bluey")
    1996 Disco 300 TDi ("Slo-Mo")
    May 2006
    Ulverstone,TAS
    Thanks guys
    Looks like the recip saw is the way to go with some water.
    Crafers West South Australia
    Start by cutting the bead wire with bolt cutters or an angle grinder. This allows you to pull on each side of the cut. Rubber cuts remarkably easily when you put sufficient tension across the cut. Any sharp blade will cut it then. Sidewall rubber makes excellent replacement exhaust hanger rubbers.
    Harold Guest
    I have only done car tyres, But a sharp sturdy knife, lubricated with water and detergent or that lanolin spray works.
