Results 1 to 10 of 11
Thread: TRS - Chipped MSB ECU surge (Td5 manual)
    South Sydney
    Exclamation TRS - Chipped MSB ECU surge (Td5 manual)
    Hi guys,
    About 6 months ago I had a TRS chipped MSB ECU installed into my 2001 Td5 manual Discovery, since then, I have noticed what seems to be an anti-stall-like feature causing the car to accelerate off when crawling offroad in low range... I've spoken to a few people in the game, and the consensus seems to be that it must be some kind of over-zealous, anti-stall.
    The thing is, it doesn't do it exclusively at near-stall, and is quite unnerving when negotiating steep descents.
    Has anyone experienced anything similar?
    The car did nothing of the sort when running a stock tune... I drove it for 4 years like that, and around the farm before that (pre-license).
    The power-curve of the ECU also seems very 'staged', like as though power comes on in bursts as you rev it out through a gear.
    Weird...
    Dec 2008
    melbourne
    Hi mate,
    I to have a Trs ecu, mine tends to do that in second gear while cruising along at about 20kmh, when you take ur foot off the gas, just before it stalls it picks up the revs and you need to either put it in neutral or use the clutch. Is this similar to your symptoms?
    I also have a slight miss around the 2000rpm mark like a bit of a flutter, have you noticed this before?
    I've recently purchased a NNN flashable Ecu in order to get it running abit smoother.
    Bronson
    Jul 2014
    west of Transylvania
    Hi, as 2001 was the tranzition year from 10P(Eu2) to 15/16P(Eu3) engines tell me please what kind of engine do you have(the AAP sensor in the airbox has 3 or 4 pins ?) and what number is the MSB ECU cos it's important(e.g. is it MSB101330 ?)
    Dec 2008
    melbourne
    I will like to check this out myself, I'll have a look later today.
    Bronson 👍
    Dec 2008
    melbourne
    Hi mate,
    Just had a look at my current ECU its a msb101330 and the airbox sensor is 3 pin. My engine is a 10p
    Hope this helps
    Luke
    Dec 2014
    Wales, UK
    That is usually down to over zealous tweaking of the smoke maps on the 700rpm and 730 rpm range. The revs drop below idle the ecu dumps in a dollop of fuel, the revs surge and the vehicle shoots forward.
    Dec 2008
    melbourne
    Quote Originally Posted by sierrafery View Post
    be good to know what this is all about
    Jul 2014
    That answer was for the OP who seems that he ignored me then you came in but as i dont know the MY of your car i couldn't tell you more, you said your's is MSB101330, is that the original one untouched or original chipped or replacement chipped? ... what are the last 8 characters of your VIN? these 101330 ECUs were used in that tranzition year 2001(from 10P to 15/16P) and there were some mapped for the 10P engines and other for the 15/16P ones but one would not work well for the other is you see what i mean
    In Aus SF all EU3 engines are factory with NNN ecus.
    Apr 2012
    Orange, NSW
    MR LRs td5 is a 10p motor.
    If Bronson got his ecu from TRS then they operate on an exchange basis, unchipped MSB for chipped MSB
    Sent from my HTC One using AULRO mobile app
    The Phantom - Oslo Blue 2001 Td5 SE.
    Half dead but will live again!
    Nina - Chawton White 2003 Td5 S
    Slowly being improved
    Quote Originally Posted by Judo View Post
    You worry me sometimes Muppet!!
