Page 1 of 8 123 ... LastLast
Results 1 to 10 of 71
Thread: Running rough and lacking power
    May 2010
    Mindarie, Western Australia
    This one's got me stumped
    Over the past couple of weeks the car has started running really rough and gulping down petrol like there's no tomorrow.
    The car is a 1996 GEMS 4.6 petrol only (no LPG)
    Symptoms, running rough, low irregular idle speed, struggles up to around 3000 RPM then appears to run smoother, very rich exhaust smell.
    * I have hooked up the Faultmate FCR and no errors are detected.
    * I have removed all of the spark plugs and they all appear the same black sooty appearance of an engine running too rich, but thankfully they are all the same!
    * I cleaned the MAF sensor just in case it was giving false readings - no change
    * As a long shot I plugged in the Bluetooth OBD11 and turned on the Torque Pro App. And it shows "open loop due to insufficient temperature". After driving for an hour in 35+?C there was ample time to get up to temperature!
    * I have checked the temperature sensor output and the voltage varies with the engine warming up to eventually sit at around 1v at operating temp (as per RAVE).
    What else can be checked that could be causing the problem?
    Gary
    Crafers West South Australia
    Check the fuel pressure regulator isn't dumping fuel into the inlet manifold via its vacuum hose. This is a relatively common problem. Without oxygen sensors your ECU cannot detect over fuelling.
    Oct 2007
    Williamstown, Victoria
    Maybe try cleaning the MAF sensor electrical connector plug with contact cleaner.
    Could also be a faulty maf, do you have access to a known good one you could swap over?
    May 2010
    Thanks guys. I'll let you know the outcome
    Gary
    x2 ...the rich exhaust smell and irregular running at lower revs is a sure sign... initially like the over use of a manual choke in an "old" car, In this case however, as revs increase, the availability of more air compensates somewhat for the over fuelling... hence the tendency towards smoother running over 3,000 rpm...
    Jul 2013
    perth wa
    Hi Gary,
    Guessing you've tried the obvious - blocked air filter?
    How about an air leak somewhere, although this would normally then run weak, but an easy check with a can of spray.
    If it is down on power, the excess fuel maybe from just being heavy footed, so maybe sending you off down the wrong path.
    I can't remember what mines like, but is it running on a dizzy, or is it coil packs like the later?
    Could it be something silly like the timing?
    I've got the nanocom if you want to try that.
    Jan 2015
    DarwinNT
    My "new" D2 has similar symptoms and they found two faulty oxygen sensors when I had it serviced. Hopefully these will fix my problem when they arrive & are installed.
    Jan 2015
    DarwinNT
    What's the fix for this particular problem with the fuel pressure regulator?
    I'll probably mention it to my mechanic if the new oxygen sensors don't do the trick.
    Avoca Beach
    To me the most likely cause is simply that the water temperature sensor has gone high resistance either because of a dirty contact or stuffed sensor. This confirmed by the error message. The only way the ECU knows the temperature is from the sensor. It doesn't matter if its 50C outside!LOL
    Try a new sensor first. Just to confirm AFAIR there should be 300 Ohms resistance at 82C plus so if it is 1000 Ohms or whatever, the choke is still on.
    Regards Philip A
    Quote Originally Posted by DaveA1963 View Post
    A 1996 P38 doesn't have oxygen sensors and a D2 doesn't have an underbonnet fuel pressure regulator so the fixes are totally unrelated.
