Results 1 to 6 of 6
Thread: D4 sump guard differences?
    dmdigital's Avatar
    Question D4 sump guard differences?
    Looking at getting a sump guard after easily removing the light grey plastic bit last weekend.
    Question is LR have a pre 2014 model VPLAP00094 and a 2014+ model VPLAP00189 (both are non-winch versions). From what I can tell the only difference is the earlier one is fitted using 2 M10x35mm and 2 M10x45mm where as the later one uses 4 M10x45mm instead. Is there any other differences?
    Most other suppliers seem to have only a D4 guard e.g. Britpart DA7535, and others like GOE specify 2010-2013.
    So besides a genuine sump guard what will fit a MY15 D4 without having to trim anything?
    Muskie's Avatar
    Muskie is offline Fossicker Silver Subscriber
    Dec 2014
    Cashmere, Brisbane
    hey there Bushie, ive got a Genuine LR Alloy Front guard and i didnt have to trim anything at all. Simply remove the plastic panel, the two - LHS and RHS front air splitters and install ! the instructions did illustrate to throw the splitters in the bin but i 'trimmed' them up and re-installed them..
    my car is a DEC 13 build and not sure if the MY14 build is much different
    MY13 Discovery 4 SE 3.0 SDV6 - Enhanced, LR Rack with LR Ladder, Johnson Rods, LR Front Alloy Sump Guard, Muskie designed Compressor. Guard, 285/50/20 Nitto's, Maxtraxs(4), 65l Waeco CFX, ARB compressor, 55' Curved LED bar, RedArc Dc/Dc charger & TowPro
    Williams West Aust
    What were you thinking Derek????
    These vehicles are only for collecting lattes or for soccer mums to collect the kidz
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    dmdigital's Avatar
    I know, I know but I've run out of fresh coffee beans for the espresso machine and the cold drip takes 6 hours for a brew.
    That light grey plastic bit on the bottom of the front skirt sure didn't like the 4th of the deep puddles, picked it up on the way home. No damage just pulled straight off with the pressure of the water.
    Muskie, that's my problem, I don't think they are different except for bolt lengths.
    Muskie's Avatar
    Dec 2014
    Cashmere, Brisbane
    happy to take mine off and give it to you to try out, as well as my bolts....but im in Brisbane....
    dmdigital's Avatar
    Bit far to travel and the track out is closed for the wet
