Thread: Wheel nuts
    Wheel nuts
    Hi all, are the wheel nuts on a D4 the same as those on a D2a (including the lock nuts)?
    2003 D2a Auto TD5 good Landy gone
    2015 D4 probably the most amazing yet, why get a RR?
    No.. Substantially different
    Brisbane,some of the time.
    Pity,the D2a nuts and studs are a lot stronger.....
    By design maybe, however *I* am yet to hear of a D3/D4 stud/nut failure..
    Over engineering for engineering sake is nice but not necessary.
    Just for the record
    The local LR indi that my brother uses,i don't use him,often gets tyre fitters coming in for studs and nuts for D3/4.
    I have a D4 nut here that is very badly stretched.It was overtightened on my D4 by a tyre fitter
    The clown didn't know the difference between ft/lbs and nm.
    Looking at the nut it appears they are made to fail before the stud breaks.
    But sometimes the stud will still break.
    I also haven't heard any reports from anywhere else on this issue either,nothing on here either.
    That demonstrates 2 key points..
    1. Rattle guns are bloody powerful.
    2. You can't fix stupid
    A majority of tyre fitters are clueless morons.
    Only a few select shine above all others for care and quality service.
    Oct 2014
    Brisbane West
    Can anyone recommend where to get good quality affordable black nuts for when my compomotives arrive?
    james
    MY11 SDV6 HSE, e-diff, LLAMS, Snorkel, Rhino Pioneer Rack, DBS, BFG KO2 265/65r18, Mitch Hitch, GME TX3550s, GOE stuff....
    Dec 2011
    Forrestfield WA
    The GOE wheels need the standard LR nuts. I assume you are after a black version to replace the chromed nuts?
    On the other topic of nuts, I had to change a tyre at Mount Augustus and couldn't remove one nut because the .5mm metal cover was destroyed by a tyre fitter and a socket wouldn't fit. One of the guys we were with had a cold chisel, which I used for at least 30 minutes and finally managed to destroy the thin cover and get a 1mm smaller impact socket to fit and get the nut off, despite the fact that I also damaged the nut underneath the thin metal while trying to remove it. A bit scary when you are about to leave camp in a very remote part of WA!
    Bob
    Oct 2014
    Brisbane West
    Yep
    LRD414's Avatar
    Oct 2014
    nuts
    James,
    I asked same question the other day and got a tip from Ian. See link below but be aware, they are expensive. I've decided the standard nuts look pretty good anyway...
    http://www.aulro.com/afvb/d3-d4-rrs/...ml#post2307030
    Link to my D4 Build Thread
    D3 2005 V8 Petrol
