Thread: Tailgate lock D4
    mawhite Guest
    Tailgate lock D4
    Ok so the user manual doesn't explain too much on this but this is what we often experience.
    1. Will unlock the car
    2. Might open tailgate to put stuff in - close
    3. Get in and start car
    4. Wife will then come and go to open the tailgate and it wont open
    5. Need to press the unlock button a couple of times.
    So once the car is started does the tailgate lock? Or is there some trick to get it to open more easily?
    thanks
    Michael
    Brisbane,some of the time.
    Has to be in park so it can open,i know,a PITA
    Williams West Aust
    Wont open the rear door whilst running I think????
    Over the 2 press to unlock all too.Sometimes Im sure Ive double cliked unlock and Deb cant get in.Living in the country it isnt needed,however when visiting places like Royal Perth Hospital and the parking areas around there it well worth having,just in case.
    Andrew
    DISCOVERY IS TO BE DISOWNED
    Snow White MY14 TDV6 D4
    JamesH Guest
    Tailgate lock D4
    Andrew
    My old MY12 doesn't have double click for all doors, it's a user selectable thing isn't it?
    I think you are right about the tailgate. It's either that or must be in Park
    SBD4's Avatar
    SBD4 is offline A Keeper of the TGO Gold Subscriber
    Dec 2011
    Bundeena
    To be clear, the double click unlock is user configurable.
    The tailgate:
    • will not open unless in park. You may still need to unlock the car once park is selected
    • will re-lock when closed if the car was already locked and the tailgate open button on the fob was used to open the tailgate
    • will lock (along with other doors) if the car has exceeded 8kph if the drive away locking feature is enabled(user selectable)
    There may be other conditions when it (re)locks.
    Sean
