Results 1 to 10 of 20
Thread: Concrete paint for shed/workshop
    Douglas Park, NSW
    I've been doing some research into protective coatings for my shed floor & like the sound of Bondall Garage & Factory Floor Protector.
    From what I've found online, it's not going to be as hard wearing as the 2 pack epoxy set ups but it is a lot cheaper & I've only read positive reviews of it so far.
    Some say it's a bit softer than the epoxy finishes & as a result is less likely to chip if tools are dropped on it.
    Has anyone used this before? Any problems?
    https://www.masters.com.au/product/9...anite-grey-10l
    My shed is 225 sqm & I've done approx. 55 sqm where my racking is in regular driveway clear so I have approx. 170 to do.
    I'm tempted to do my workbench area first & see how it holds up before doing my hoist area.
    Jun 2007
    Margaret River
    Have you checked out Gecko?
    Had good report from a mate that uses it on factory floors.
    Not sure of cost but highly rated
    Gecko Special Coatings - Safety Floor Coatings, Anti-Slip Flooring and Non-Slip Floors
    WA
    Quote Originally Posted by Grappler View Post
    I know one of the owners of that company. I haven't used it, but it sounds like good stuff. You need to read the instructions properly before preparing/applying. A lot of "expert" tradies seem to have problems doing that apparently.
    Jun 2007
    Margaret River
    Are his initials GM? If its the same bloke, I worked with him at CSIRO for many years, before he got into politics and then space age coatings
    The gecko coating is a patented relative of the ceramic coating on the space shuttle heat tiles
    Torres Straits
    Scott,
    not sure of this helps in any way shape or form.
    following on from a landy workshop in Cairns, my shop in Cooktown I used "Resene Pavement Paint"
    I had thought along the lines of epoxy/ space age goodness et al
    Instead I went with a single pack easily applied (roller) paint.
    Quick light acid etch and pain
    Shed been up for 7 years now - have re-covered the central work area once and it is now ready for a freashen up.
    Now its not perfect, it chips and welding burns it and big hits like afreaking R380 flying from a bench will ding it BUT clean up of oil spills is easy (wipe with a rag) sweeping is easy (no conc dust) and I like the light colour and smooth feeling on my weary bones....
    Also Resene is relatively cheap - I think I would always recommened a painted surface in a work area but assume it will get trashed (no matter how space age) so keep the cost down enough to not worry when you need a re-coat
    Biggist bee-atch with recoating is moving all the projects out to paint the floor!!!!!
    Steve
    Not going to comment on type (although I did look at the thread related to KBS today and was impressed with their sealers), all I'd say is get it tinted or already in the can the lightest colour you can.
    Edit: I used acrylic because it is really easy to touch up if damaged. High traffic areas are fine after 4 years. Didn't acid wash, pale grey, tint available in any colour.
    Pure white is a bit much, but a really pale shade of grey (about 2 on the scale of 50 haha) makes a huge difference to interior brightness in your shed.
    cheers, DL
    Jan 2014
    Emu Park
    I think i paid about the same price for a 2 pac kit for my car port from my local paint shop the one that has the flakes you sprinkle over and it was pretty damn tough! I was happy with it.
    Douglas Park, NSW
    Quote Originally Posted by roverrescue View Post
    I get the impression that the Bondall paint fits between the regular pavement/concrete paint & the 2 pack epoxies.
    I don't mind putting down the dearer stuff but I don't want to find out that welding spatter melts into the surface & I have a hard time removing/repairing it.
    There's a water based epoxy paint by Rust-Oleum which works out at around the same cost as the Bondall per sqm but is more time consuming to apply:
    https://www.masters.com.au/product/1...or-coating-kit
    but it seems the water based epoxies aren't as strong as the solvent based ones.
    WA
    Is there any paint/epoxy that is impervious to weld spatter? I have seen weld spatter melt its way into a glass windscreen, so if you are welding close enough to the floor I would expect it to affect any surface coating...
    Douglas Park, NSW
    Probably not which is why I'm leaning towards the Bondall as it's just a single pack paint which should be easy enough to repair/repaint when the time comes.
