Results 1 to 9 of 9
Thread: Towbar tongue to suit LR hitch box
    Feb 2011
    Hobart, Tasmania, Australia
    Question Towbar tongue to suit LR hitch box
    The hitch box on my D2a measures 54mm (or 2 1/16") square but the towbar tongues available all seem to be 50mm (or 2") square. I have two here that I have tried and they make horrible noises at low speeds due to the sloppy fit. Anyone sourced a decent tongue to suit the size or just used a packer with the 50mm one?
    Doesn't your hitch have a bolt in the side to clamp the tongue into the receiver to stop that?
    Jan 2010
    Lyndoch Brossa Valley
    Towbar Tongue
    I just spotweld a strip of 50mm wide 1/16 thick to 2 sides and lightly linish to fit tightly . No more rattles.
    Bairnsdale enjoying the rural view no rooftops to see here
    PM SENT
    have a good one :D ken :wasntme:
    MY07 L320 RANGE ROVER SPORT MORE GOODNESS TO COME
    MY03 D2A TD5 EXTRA GOODIE ENHANCED :D now parting from life
    1996 D1 300TDI GONE
    08 ford ranger c/c
    WRECKING DISCOVERY 2
    PM ME FOR WHAT YOU ARE LOOKING FOR
    darwin
    I just wrap tape around the gooseneck,last a few months
    Darwin
    03 disco 2a td5
    93 tdi disco [gone to a better home]
    2003 d2a v8 retired hurt
    1988 k100rs bmw gone
    85 county izuzu [gone to a better home]
    69 series 2a [gone to a better home]
    series 2a [gunnado]
    series 3 [gunnado]
    and the tinny
    Mar 2009
    Port Stephens N.S.W
    Doesn't exist on the D2.
    I have the same issue. Factory 4" drop tongue is a better fit, but I'm using a 2" drop with a bit of extra length to carry the Tregg that the kamper's hitched to ... doesn't really make any noise at any speed due to the higher ball weight. It sits solid as there's plenty of down force on the tongue (Kimberley Kamper)
    Is it OK from a strength point to weld some thin plate to each side ??
    ... or, as the OP asked ... ??
    Kev..
    2014 Isuzu MUX LST with fruit
    2008 Isuzu D-Max
    2015 Kimberley Kamper "Classic"
    Gone ... 2004 D2a Td5 Auto "Classic Country" Vienna Green
    Have a look at this video from about 1:30 to 3:30 mins.
    [ame]http://www.youtube.com/watch?v=BPWjzLTsjhg[/ame]
    Mar 2009
    Port Stephens N.S.W
    Thanks Ron.
    Probably not too hard to do to the D2. My D-Max factory bar has a single bolt/nut at 45deg in the corner of the hitch reciever which applies pressure against the corner of the hitch, but from your video link the idea of a side at the rear and a bottom at the front makes good sense.
    ... but I don't have a rattling issue as there's a decent weight on the KK drawbar. This will be one of those when I get around to it mods!
    Thanks.
    Kev..
    2008 Isuzu D-Max
    Jun 2008
    The new Gold Coast, after ocean rises,Queensland
    I have a hayman reese bar and the tongue fits tight....also has a pin secured by an R-clip.
