Thread: Recon Auto, big delay D or R when cold
    Kallangur, Brisbane
    Just had a reconditioned auto with an additional tranny cooler fitted by a reputable dealer. When cold, it takes about 30sec after selecting D or R before any movement happens even with the revs at a fast tickover.
    The pan has been removed & another filter fitted in case the O ring was incorrectly seated. Also filled with new oil. Once initial drive has started, the box works fine.
    I'm wondering if the problem is with the auto box or with the additional oil cooler plumbing. Should there be a non return valve somewhere to prevent the oil draining back maybe? Has something been assembled backwards in the box?
    My old, very worn box displayed the same symptoms when cold but not for anywhere near as long a time. Should I be worrying?
    + 2016 D4 TDV6
    St Helena,Melbourne
    4.28 MB
    In a rebuilt trans i would be worrying , who fitted the trans ?
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Kallangur, Brisbane
    I'll keep quiet about who fitted the tranny for now but I am sure that they will do the right thing. I just have to be sure of my facts.
    + 2016 D4 TDV6
    Kingston, Tassie, OZ.
    Definitely an upstream air leak possibly even somewhere in the pump housing or the valve body where it is attached to the main case. I have seen a similar symptom although not as chronic as you are experiencing when the valve body separator plate gasket is torn or not sealing.
    Jc
    Kallangur, Brisbane
    Jc
    Thanks JC,
    Is any of this a fix with the box in the car?
    + 2016 D4 TDV6
    St Helena,Melbourne
    4.28 MB
    I would go back to the fitter , if you stuff it you will be stuck without any warranty.
    1974 VW Kombi bus
    Kallangur, Brisbane
    The fitter is aware of the problem & has replaced the filter as the first fix. I have no doubt that it will be rectified somehow.
    Considering the amount of money I have paid for all the works done on the vehicle, I don't plan on spannering it myself. I'm just trying to gain a little knowledge so that I am better able to understand what could be wrong.
    Thanks again.
    + 2016 D4 TDV6
