Results 1 to 10 of 12
Thread: Brake Squeal noise. Then the 3 Amigos!
    Ferntree Gully, Vic
    Arrow Brake Squeal noise. Then the 3 Amigos!
    Tonight after l started the Disco Td5 to leave work, I noticed a really bad brake squeel. It was really high pitched for a few seconds and then the hill descent, ABS and Traction control light came on. The brakes have only about 10,000 km on them so are quite new. I replaced the pads at the same time as well. I think they were Bendix pads.
    I have noticed over the past few weeks that the squeel has been coming up when the brakes were cold. The first couple of presses and you could hear it. After that you wouldn't hear a thing.
    I haven't checked on the Nanocom yet for any codes. So what would be causing this squeeling noise? Any suggestions?
    Nov 2014
    Nirvana near Albany W.A.
    You will need to remove pads , check to make sure they are Bendix , if they are you could de glaze discs with emery tape as well as the pads.
    To do pads , place emery tape on a flat surface and lightly move the pad over it in a circular motion, also take the sharp edges off , also apply anti squeal to back of pads,
    The squeal is the result of vibration which also sets up a harmonic, causing a visit from the 3 amigos
    Did you use anti rattle on the back of the pads when you installed them?
    Ferntree Gully, Vic
    No I didn't use itBrake Squeal noise. Then the 3 Amigos! Can I just get it from any parts shop? Looks like I'll be doing that this weekend if it's not to late to do.
    Jul 2010
    Hunter Valley NSW
    I found the rear pads (bendix) oversized running over the edge of the rotors wearing a ridge in the pad causing squel.
    Quote Originally Posted by SPROVER View Post
    Yep, Supercheap even sells it in one use sachets...
    Stops pad to disc resonance and hence squeal and Amigoes
    Ferntree Gully, Vic
    I'll be buying some this weekend and doing it. I checked on the Nanocom and it came up with low resistance on LH side which is where the squeel noise came from.
    Jul 2013
    Port Macquarie
    What is the best brand of brake pad to use? Im looking at replacing mine shortly...
    Nov 2014
    Quote Originally Posted by EddyEddys View Post
    Bendix front. Db 1336 4wd
    Rear db1285 4wd
    Jul 2010
    Hunter Valley NSW
    IMHO the best budget pads, cheap and US made
    No shims or anti rattle, better fit
    No dust and less pedal effort required
    Dont bag them if you havent tried them
    http://www.repcotrade.com.au/go/prod...-thermo-quiet/
