Results 1 to 10 of 20
Thread: Calling all Fuel Injection Experts!! D2A V8 O2 Sensors
    Hi all, as the title suggests I am at wits end again with my Discovery 2 V8.
    The problem so far......
    I have recently rebuilt everything in this car including diffs, transfer case, and the entire engine. The engine was fully rebuilt, tophatted, heads done, all mickey mouse.
    After firing the engine up and driving for a few months I noticed that the vehicle always smelt 'fuelly'. I plugged in a Lynx diagnostics system and It came up with a myriad of O2 sensor faults. Lots of them would have been there long before I rebuilt the thing. Long story short I have ended up replacing both O2 sensors with Bosch units (AU Falcon Style), and the connections going to them. I have checked wires for continuity right to the ECM and have checked fuses in fuse box. Everything checks out OK.
    I have also reset ECM adaptations each time I have fiddled with something.
    The problem now is that the left hand Bank (bank 1) just will not work correctly. It sits on about a .45 to .58 V O2 sensor reading (from the Lynx diagnostics) and just sits there. The RH bank (bank 2) works as it should and alternates above and below the mid range voltage (.45 V I think)
    The fuel trim on the RH bank goes up and down. The left just sits.
    MAF reading is from 20 kg/hr up to 300 odd when you boot it.
    The engine runs fine, bit low on power and still smells a bit fuelly.
    I have swapped the spark plugs from Left Bank to Right and vice versa, the plugs all looked the same (nice Burn) and the problem stayed with the left bank.
    I will always get the following codes about five minutes after staring.
    O2 probe heating before Catalytic converter-Minimum Value Not Reached. Fault present and Static
    O2 probe pre catalyst - signal missing. Fault present and static.
    On a few occasions I have got the thing to go into closed loop running. When it does it lowers the left bank to minimum fuel trim, and the engine runs like a bag of snot. When this happened it also logged the following code.
    Fueling adaption ti multiplicative, minimum value not reached.
    All symptoms point to a failed O2 sensor, but when you swap sensors from side to side the problem stays with the LHS. So you would then assume a wiring problem, but I have renewed both connectors and the wiring is OK from the sensor to the ECM (checked with multimeter continuity tester)
    The signal wire to the ECM (input) is connected to the black wire on the O2 sensors, and the earth to the grey. There is 14V from the ECM for the heaters.
    I am out of ideas. Short of replacing the ECM or burning the thing to the ground I am unsure where to go from here. I think the fact that only one side is playing up rules out the MAF sensor.
    Would a stuffed catylytic converter have an effect on the operation? Looking at the LH down tube the LH bank has been running rich for a while..
    Any advise or thoughts would be greatly appreciated as I am starting to type 200 series Land Cruiser into carsales.com a bit to much for my liking lately....
    Crafers West South Australia
    Make a test rig with a spare O2 sensor, see that the 14V heater voltage is present at the sensor with it plugged in and drawing current. Your adaptor cable may have a dodgy joint. They should never be soldered. I use special small uninsulated crimps then heat shrink the joints.
    Avoca Beach
    I know it is pretty basic, but have you checked the continuity of the circuit between the ECU and the LH O2 sensor.
    I take it you have crimped the leads if they are Falcon O2 sensors as the stainless stuff is hard to solder.
    So my advice is to just check the continuity.
    The other possibility is that the earth return for the O2 sensor is poor on the left bank. If they are 2 wire sensors the earth return is via the exhaust pipe presumable to the head . This may be poor on the LH bank so maybe run an earth wire from the manifold to the head.
    Regards Philip A
    I purchased a tail from the AU falcon harness with the sensors. This means the wires are solderable which I have done. There is no cutting into the original sensor harness as it plugs into the new AU style plug. In saying this, I will check it at the sensor itself like you say.
    The fact that the sensor registers a voltage soon after starting indicates that the heater is working, but seems to want to log a fault.. Just like if the sensor is returning a voltage that varies between .45 and .69 volts, there must be some sort of signal returning from the sensor... It just won't register it and make the fuel changes..
    Regards Philip A
    The wires were soldered into a replacement AU harness tail. The sensor wires themselves have not been cut and are in their original connector. I have checked continuity from the new plug, to the ECU plug. All good and wired correctly.
    They are a 4 wire sensor so the earth is through the wiring harness. This has been checked for continuity to the ECU plug as well. I have the black wire from the sensor attached to the signal wire to the ECU (blue or orange depending on which side) and the grey wire attached to the red/black earth wire. Is there a way of testing the earth into the ECU? I have checked the continuity but only to the plug into the ECU
    ashhhhh Guest
    Its generally considered bad practice to solder o2 sensor connections.
    I would buy new ones with the connector attached if I were you. I got mine from Amazon for $45 each.
    Your symptom of one bank showing no activity is exactly what I struck with mine.
    I had;
    P1000 = LAMBDA SENSOR UPSTREAM
    CATALYST BANK 2 DRIVE CYCLE C
    OCCURED 7 TIMES
    SIGNAL INVALID
    FAULT IS CURRENTLY PRESENT
    FAULT DETERMINED AS INTERMITTENT
    FAULT DOES NOT CAUSE THE
    MIL LAMP ACTIVATION
    P0175 = MIXTURE ADAPTION FACTOR
    FRA BANK 2 DRIVE CYCLE C
    OCCURED 1 TIMES
    SIGNAL TOO HIGH
    FAULT DETERMINED AS PERSISTENT
    MIL LAMP ACTIVATION
    I replaced o2 sensors, MAF, checked wiring etc.
    It turned out to be caused by an air leak at the inlet manifold joint, probably injector o-rings too.
    Sorted all that, no more issues.
    Quote Originally Posted by ashhhhh View Post
    I had;
    OCCURED 7 TIMES
    SIGNAL INVALID
    MIL LAMP ACTIVATION
    OCCURED 1 TIMES
    SIGNAL TOO HIGH
    MIL LAMP ACTIVATION
    When this happened to you Ashhhhh, was it reading a voltage like mine? or was it either to high or too low? the thing that confuses me is if it is an air leak or similar, wouldn't the voltage be reading right down low indicating its too lean on that bank?? Mine is varying between .45 and .69 V
    PS, I have only soldered the AU plugs into the land rover engine harness. All wiring for o2 sensors has not been touched from new, as in they came with AU plugs installed.
    ashhhhh Guest
    I dont recall actual voltages but the symptom was that one bank fluctuated a lot and the other was very low and basically static. (like 0.15 low)
    So yeah, your right - lean in my case.
    Do you have any P codes to go with those descriptions?
    Avoca Beach
    I wonder if it is one or more crook injectors.
    Regards Philip A
