Results 1 to 10 of 13
Thread: Downloading Direct From Camera
    Mar 2012
    Armstrong Creek, Qld
    I had a bit of a glitch with my camera & after getting it up & running again, I was advised by the technician to always download from the card, never direct from the camera! I'm taking his advice.
    Yes/No?
    Steve
    Sussex Inlet. N.S.W.
    I remove my card and plug into a usb port via a card adapter. Jim
    Jim VK2MAD
    '17 Isuzu D-Max
    St Helena,Melbourne
    4.28 MB
    Quote Originally Posted by jx2mad View Post
    Same here and use the import function in windoze.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Apr 2002
    Godwin Beach 4511
    32.43 MB
    i always download diect from the camera using nikon viewnx2
    free download and works with most brands of camera or cards
    using the card directly can be quicker but i dont like disturbing cards all the time.
    not to mention many people are their own worst enemies by putting their fingers on the cards contacts when they handle them.
    2007 Discovery 3 SE7 TDV6 2.7
    2012 SZ Territory TX 2.7 TDCi
    Quote Originally Posted by incisor View Post
    Not a problem with CF cards.
    However, I have found that pushing a CF card in to a reader can bend the pins in the reader. I've had to dismantle the USB3/Multi-Card reader to straighten them.
    May 2002
    Heathcote (in "The Shire")
    I always used to download via the camera, now I go straight from the card, due to the time involved.
    Martyn
    That's the reason I installed a USB3/multi-card reader into the desktop PC.
    Apr 2010
    South East Queensland near the sea...
    I always pull the card out Steve, I just find it easier.
    TRS Chip ,D2a I/c, Silcone Hoses, EMS2, 2" Lift, BFG KM2s, QT Diff Guards, 4X4 DE Guard, Shadow Bar. VRS Winch, LR Light Guards, .50 CDL, Provent 200, Slickrock Disconnects, Rovadrive Sump, G4 Roof Rails, D2a SLABS ECU, APT Sliders.DBA Rotors. ABS Ext.
    Oct 2014
    Salisbury Downs, SA
    Card out is quicker when dealingwith RAW etc. Also a decent card reader will make a load of difference (I had a $5 chinese card reader that if you left the card in you would get magical spyware put on the card)
    I run
    ImageMate All-in-One USB 3.0 Memory Card Reader by SanDisk
    However, downloading via the camera is designed when the camera was created. If it is causing you issues then it is a fault on the camera and should be recalled.
    Quote Originally Posted by iPom View Post
    If I've only got a few images, e.g., after having taken just a few to illustrate a post on the forum, I'll plug into the camera. When there are a lot of images, a card reader is much faster than the camera connection - especially on my oldest DSLR.
