Traction control and ABS springs to mind as the big differences, other than that was just cosmetic IIRC although also stuff like AC, tow pack standard, leccy front windows.![]()
Just curious, but what made the "Xtreme" Td5 Defenders "Xtreme"?
What were/are the differences?
Anything considerable?
From memory only the first td5 fenders were non extreme models (1999) and the rest were extremes ie only one model.
Sent from my GT-I9300 using AULRO mobile app
2004 Jayco Freedom tin tent
1998 Triumph Daytona T595
1974 VW Kombi bus
1958 Holden FC special sedan
The extreme had TC/ABS AC power front wintodws ,tow pack heavy duty springs/shocks bar work and allys
it was the option up pack for the standard defender for a couple of years, it then became the standard for the 90/110s but you could order the base spec if you wanted to.
the 130s remained in standard trim but could be had with most of the options of the extreme but there was a period where th ABS/TC wasnt available for the 130. Ive seen td5 130's with ABS/TC but im not sure what trim level they were at or if it wasnt an owner retrofit/special order.
First xtremes came out in 1999
With ABS, Traction control Air conditioning and Bull Bar
Metallic paint and Mag wheels
The first 40 or 50 were a limited run to test the market
My 99 Xtreme has ABS/TC, Alloy mags, Air con, Metallic paint BUT no power windows. What was the Tow pack?
Cheers for that fellas, was just curious.
So technically, other than the bull bar, all the new Doofers are "Xtreme" too...??![]()
No Power windows and standard suspension on first Xtremes
