Results 1 to 10 of 11
Thread: Can you check for a cracked TD5 Head prior to purchase?
    Aug 2014
    North Stradbroke Island
    I am looking at buying a D2a TD5. Is there any way to check whether it has a cracked head prior to buying it?
    An oil analysis would be a way to check it maybe?
    Aug 2014
    There are two issues which the cracked head causes I think:
    1. Diesel in the oil (sump)
    2. Diesel in the Coolant
    I think that's right???????
    St Helena,Melbourne
    4.28 MB
    Depends where the crack/s are , might just overheat or pressurize the cooling system.
    Sent from my GT-I9300 using AULRO mobile app
    2004 Jayco Freedom tin tent
    1998 Triumph Daytona T595
    1974 VW Kombi bus
    1958 Holden FC special sedan
    Aug 2014
    I know that the TD5's can have cracked head issues, I had one that gained oil and added diesel to the sump.
    Not sure about the coolant side of things, is that the issue that the TD'5 are having with some of the cracked heads and coolant Loanrangie?
    Aug 2014
    The Results!
    Having done some research I've discovered 4 ways to check for a cracked head as follows:
    1. Check dipstick, smell oil for diesel smell
    2. Oil sample test via Wear Check Pty Ltd
    3. Blotting paper test as discussed above
    4. Remove rocker cover, clean inside so that its spotless, run fuel pump through test book, observe visual diesel ingress via microscopic cracks in head (this works a treat apparently)
    Don't know how to check for leak into coolant system though?
    Last edited by Islandnomad; 2nd March 2015 at 11:15 AM. Reason: add blotting paper
    Jun 2013
    Augusta WA
    A leak into the cooling system is easy to check. If it is diesel you will see small globules floating at the surface of the header tank and some staining of the inner surface of the tank. In bad cases you can dip paper in and it will burn (after you remove it of course). Or if it is oil much the same but more scum. On a good working head and cooling system the header tank and coolant should be pristine.
    Nick
    Jun 2011
    Victoria - Pakenham
    There is a chemical test you can do that checks for exhaust gasses in the cooling system. Mechanics use it all the time. I'm not sure if this will really help you with a cracked head.
    All the tests check for fluid contamination and won't distinguish the difference between a head gasket and a cracked head. Which are totally different issues, well financially anyway.
    Nov 2014
    Nirvana near Albany W.A.
    The chemical test is called a tk test , where , if gases in cooling system are detected the chemical will change colour from blue to yellow
    Usually can be detected by bubbles in the coolant / overpressurising without using the tester
    I'll add that most of the time diesel in engine oil can be attributed to fuel injector o rings, not necessarily cracked head
    Also sometimes a bit of residual sludge in expansion tank could be down to leaking oil cooler
    Jul 2014
    west of Transylvania
    One of the worst scenarios(happened to me) is to be a crack on the coolant circuit in one of the inlet ports then will be no other symptom than very slow coolant level drop without any trace of a leak, the very small amount of coolant which is leaking there is 'atomised' in the combustion chamber... killed my nervs for almost a year as i couldn find the leak what ever i did untill the head came down for a pressure test then the painfull reality was revealed.
    South Yundreup,WA.
    Quote Originally Posted by sierrafery View Post
    I reckon mine has done the same on the Defender.
    2011 Discovery 4 TDV6
    2009 DRZ400E Suzuki
    2003 WK Holden Statesman
    Departed
    98 Ducati 900SS Gone & Missed
    Facta Non Verba
