Thought I would get at least one reply.........![]()
I want to replace the camshaft in my Disco 2 4.0L engine while I have it in a million pieces. Looking to maybe get one that gives it some more torque. But not sure where to get it from. Anybody know what is available and where to get it ?![]()
Mate i will hunt for the receipt for mine. It was a Crowe cam from memory...second stage tow cam. Cheers
Do you want one made in Oz?
Mines a H180 Kent cam from England.
Any company that can grind a cam can do one.
This from Crow
'97 to '07. sold.![]()
Ok mate this is mine
371613 - RANGE ROVER 4.6 HI TORQ CAM - 371613 - RANGE ROVER : CrowCams
Certainly gave it more urge in middle rev range - more towing torque. You could tell it was not stock without a load but more noticeable with a load - with a heavy load you could tell the difference, although the difference was not huge. I wouldnt go with this cam unless towing all the time. I understand that the High Compression 4.6's cam has higher and longer valve opening.
Make sure you replace the lifter alsoo , other wise you end up like others with premature wear.
So, ozscott, will this cam suit a 4.0L Hi comp engine ?
Mate mine is a high comp 4.0 D2, late 2001 build before the d2a. I did lifters too...
