The reversing light work?
Hi folks. I'm hoping someone can identify the loose wire I found hanging underneath my TD5 this afternoon. It seems to originate from up behind the transfer case? Doesn't seem right, just hanging there...
Its marked by the red arrows in the top quality iphone photo attached.
 Wizard
						Wizard
Yep. All lights are functioning as normal.
Looks like the difflock light cable, is that working?
That could be it. I'll check today.
No. Difflock light is working. Should there be a light for low range?
There isn't a low range light, but there is a high/low range switch to tell the ECU which throttle mapping to use.
My guess is it is off the handbrake.
