Results 1 to 3 of 3
Thread: Problems after msv2 upgrade
    Jun 2007
    Margaret River
    After software and firmware upgrade to latest 1.33
    When hooked up to rrs to explore and clear some faults- next morning flat battery in vehicle
    Recharge battery and vehcle running but now audio controls on steering wheel are mixed up - mode increases volume
    Im thinking the msv2 is not allowing the ecus to go to sleep and drained the battery
    Any suggestion on what could be going on
    NSW SW Slopes
    Did you change any CCF settings? If not then perhaps the battery going flat caused a mix-up so suggest that you disconnect the battery for a minute.
    Jun 2007
    Margaret River
    No, didnt change any configs
    Just scanned for faults then used clear faults from entire vehicle cmand
    Yes i tried disconnecting the battery to reset the ecus but radio controls on wheel are still muddled
    The battery is holding its charge after going flat following use of msv2
