I decided to see how hard it is to get to the pump belt as well as the pump, removed the battery, plastic housing, heat shields and disconnected two wiring harness - moving them over to the left. Pump a real git to get to, so decide it's a no go but while I am here i will blank the EGR with the kit I bought.
All back together, no missing screws, checked all connected. Go to start and am greeted with Park Brake Fault, Transmission Fault Limited Gears, HDC Fault, Suspension Light, DSC Light and Park brake is Amber.
None of these were there before. Everything checked again, hard reset, still the same.
The drive is interesting, you can floor it up to 60km/h - above 3000rpm and no issues until I hit 60 km/h when I hit with the original problem.
Any clues?
