Results 1 to 10 of 22
Thread: Perentie toolbox - tools used on the Perentie
    Western Victoria
    I need to put together a toolkit for the Perentie. One to stay with the vehicle and travel with.
    So, help me out fellow Perentians.
    Post up what tool you used and what you used it for.
    Mar 2015
    South Australia
    This is a great idea, very interested in this myself.
    Attached is a base tool kit I picked up for the back of the perentie just with the general tools you shouldn't leave home without in it, with plans to add some specialist stuff to it. I liked this one because it's 300 piece of actually useful tools, came in a handy case for the truck (stuff can't fly around everywhere), is neat and tidy, is reasonably good quality made in the states by Pittsburgh and only cost $300. It's no "snap on" or "blue point" but it'll do for on the road...
    Jun 2014
    Waitakere, New Zealand
    Prop shaft spanner, two thin wall 9/16th spanner from memory. In between a 13 and 14mm.
    in the wild New England, NSW
    Add 14mm X 17mm flare nut spanner for cracking unions and the pump bleed locknut in case you run out of fuel
    Feb 2014
    A good torch
    Funnel
    Duct tape
    Bulb type circuit tester
    Regards,
    Phil B
    Custodian of:
    1974 S3 swb wagon (sold)
    1978 S3 swb canvas
    48 749 '88 4x4 Perentie
    1985 County with 4BD1T
    Quote Originally Posted by Phil B View Post
    A good torch
    Funnel
    Duct tape
    Regards,
    if you dont have the circuit tester, the mp light is quick and easy to remove for the same purpose as is the overheaad dome light
    I'll grab a copy fo the CES for them
    Apr 2012
    samford
    Quote Originally Posted by BushBandit View Post
    Wow that's impressive Looks perfect to get you out of strife!
    LandroverScott Guest
    Mick, I have a list of the CES for a Perentie, I'll give it to you next time your at the Farm!
    Jun 2014
    Quote Originally Posted by LandroverScott View Post
    Any chance you could scan it and post it on here for the rest of us?
    Quote Originally Posted by BadCo. View Post
    Ok next week after Corowa
