Results 1 to 10 of 15
Thread: Protecting Inside the Chassis Rails
    Mar 2011
    Hi all,
    Just about to embark on cleaning my chassis and ridding the outside of some rust it's gathered over the years (and giving the welder a good workout).
    I've made some 'incisions' into the chassis and whilst the inside is ok, there is some rust forming and I wanted to pick your brains for the best way to handle it and stop it from spreading.
    I'm planning on giving everything a good squirt with low strength phosphoric acid (rust converter) but I'm not sure what do to next. What's the best way to protect the inside of the rails? I've heard fishoil and ATF Fluid but they sound messy. Is there a clean, easy product designed for this?
    AT
    AlexTurner
    WA
    Lanotec Heavy Duty Liquid Lanolin | Lanotec
    or better yet, since it sounds like you have access, spray the inside with cold gal and then follow up with lanotec after it dries.
    Galmet? ColdGal
    Nov 2012
    Acacia Ridge, QLD
    Thumbs up Lanotech
    Hi Alex, I'm thinking about the same thing myself.
    Lanotech is product we have used at work offshore for may years, and I can't speak highly enough about it. ( AKA, Kiwi aftershave )
    It's made from the oil that comes from sheeps wool. There is more than one product available but the oil from sheep's wool is the key.
    I plan to jet out the inside of the chassis rails and let them dry very well, then make some type of spray head that can be fed into the rails form the front and the back . and try to spray the inside.
    I personally wouldn't bother with the acid rust converter, one of the characteristics of the lanothech is it's very fine and will travel through the rust and seal it off underneath. I think it works similar to fish oil.
    I have seen steel bolts offshore without paint not deteriorate for years after being paint with lanotech. Its available in bulk 20 liter drums etc, 1/2 liter spray bottles or in pressure pack cans etc. I use the pressure pack cans & spray bottles everywhere , for door hinges , bolt ends under the car etc. It's not cheap though. Worth a look. cheers simmo
    simmo
    95 300Tdi Defender wagon
    Jan 2013
    Grampians, Victoria
    Another brand - same idea - is MX4 LANOX Lanolin Lubricant - Inox Lubricants
    MY13 Defender 90 LE "George"
    Apr 2010
    Connolly, WA
    Lanolin products are great, but it need reapplying annoyingly often as its an organic material and therefore completely biodegradable. You really need to reapply after every pressure wash and its way too messy to muck around like that.
    A much better and significantly more permanent solution IMO is Valvolene Tectyl 506 which sprays on pretty easy and dries as a semi hard resin type finish. Inside the chassis its a 5+ year spray and forget product, so well worth the money spent.
    [ame]http://qclubricants.com/msds/Tectyl506.pdf[/ame]
    Blackwoods sells it in 20 liter tins and you can get it in aerosol for detail work as well.
    Lou
    Oct 2007
    Wantabadgery, N.S.W.
    Penetrol is also pretty good.
    The Flood Company Australia ? Anti Corrosion Products ? penetrol-anti_rust
    And another thing. Cold Gal will only be effective on properly prepared bare steel. NO RUST.
    Don.
    Nov 2013
    I bought a can of Bilt Hamber Dynax S50 and Dynax UB. Still haven't used it yet but I am planning on trying it out in a week or two. The guys in the UK rave about it.
    It is expensive and hard to find in Aus, $50 for a 750ml can I think.
    Mar 2011
    SYD> Brisbane> currently overseas
    Simmo,
    I would be curious what/ how you make a spray head to access the inside of the rails. When you figure that out would you post pics of the 'tool'? Curious what would make a decent spray head to cover best area inside the rails.....
    Quote Originally Posted by simmo View Post
    Oct 2007
    Brisbane West
    Mate you cant go past Xtroll Rust Conqueror UV - greater specific gravity than water so it gets everywhere. Just spray it in with a spray gun and compressor so it atomises and it sets hard - its transparrent with a very light gold tinge. I use it on the Landy's and also boat trailer and caravan etc and you cant go wrong. It forms a complete seal to stop existing rust and new rust developing.
    Nov 2012
    Acacia Ridge, QLD
    Spray head
    I think you can buy them , I've seen them for jetting out cleaning pipes and coating them inside, or use small airless spray gun nozzle, of small burner atomizing head. Plus some type of spring wire legs to hold it roughly central.
    I think if you cut 1 x 1" hole on the inside of each chassis rail in about the middle of the car you could feed the nozzle each way. There is a hole at the front of the chassis rail, but I don't think it's big enough. Do you remember Aldi had boroscopes on sale? One of those would be handy to check the results.
    simmo
